justincohen Wed, 12/02/2009 - 12:51
Domin;
        Page can not be displayed (aka, nothing).   Tried that with hostname and IP..
       Seems like nothing on :80 works...   Must be 8080
dominthomas Wed, 12/02/2009 - 13:03
Please check the firewall configuration...
If you are using SMA then check the following also
Firewall
Port Configuration
Between Intranet and DMZ
Outgoing 22 to DMZ for system communication
Outgoing 4443 to DMZ for system communication
Outgoing 80, 1935 (443 if SSL is used) for end users accessing the secondary server from the Intranet
Firewall
Port Configuration
Between DMZ and Internet
Incoming 80 for end users accessing the secondary server from the Internet via HTTP
Incoming 1935 (Optional, but recommended for more efficient web performance)
Incoming 443 for end users accessing the secondary server from the Internet via HTTPS
Ginger Dillon Wed, 12/02/2009 - 13:47
  • Blue, 1500 points or more
Hi -
Something else to check.  In the address field, enter http://ddd.ddd.ddd.ddd, where ddd.ddd.ddd.ddd is the IP address of port 1 (eth0) that you entered when configuring the Cisco Unified MeetingPlace Express server.  The browser should display the Cisco Unified MeetingPlace Express application Attend page.  In DNS you can create a CNAME record for your MPE Eth0 address.  For example, mpxsystem could be used as the alias and your users would then enter http://mpxsystem to reach the Attend page.  And one last thing, the port 8080 may be used by something else on the MPE server.
Ginger
