Question about BGP routing
Dec 2nd, 2009
Hello, I have a question about BGP/OSPF routing. Please see the scenario
example Router A
GI1/1 10.10.2.1/30 -----EBGP link to router B
Router BGP 500
neighbor 10.10.2.2 remote-as 600
example Router B
GI1/1 10.10.2.2/30 -----EBGP link
VLAN 5 192.168.1.6/30
loop0 192.168.1.2
GI1/2 switchport access VLAN 5
Router BGP 600
neighbor 10.10.2.1 remote-as 500 ------  EBGP link to router A
neighbor 192.168.1.1 remote-as 600 ------- IBGP link to router C
Router OSPF 600
passive-interface default
no passive-interface vlan 5
network 192.168.1.2 0.0.0.0 area 0
network 192.168.1.6 0.0.0.0 area 0
Assuming Router B has an IBGP connection to Router C.
example Router C
VLAN 5 192.168.1.5/30
loop0 192.168.1.1
Router BGP 600
neighbor 192.168.1.2 remote-as 600 ------ IBGP link to router B
Router OSPF 600
network 192.168.1.1 0.0.0.0 area 0
network 192.168.1.5 0.0.0.0 area 0
network 192.168.1.9 0.0.0.0 area 0
when I do a show ip route 192.168.1.9 form router A, I get the below output.
sh ip ro 192.168.1.9
Routing entry for 192.168.1.8/30
  Known via "bgp 500", distance 20, metric 0
  Tag 600, type external
  Last update from 10.10.2.2 7w0d ago
  Routing Descriptor Blocks:
  * 10.10.2.2, from 10.10.2.2, 7w0d ago
      Route metric is 0, traffic share count is 1
      AS Hops 1
      Route tag 600
My question is how is it that I have a route entry in Router A known via BGP when BGP is not advertising any networks on any of the routers and OSPF is not being redistributed into BGP?
Note - There is a route-map on Router A that basically says Router A can only advertise the default-route out to router B. Please let me know if anything needs to be clarified. Thanks,
Reza Sharifi Wed, 12/02/2009 - 14:57
Based on the configs you posted, I see a couple of issues with your design.
1-Network 10.10.2.0 is not being advertised to OSPF on router-B, so if you try to ping 10.10.2.1 or 2 from router-C it will not work.
2-You have configured the IBGP connectivity between Router-B and Router-C with physical IP addressess. although it works, it is not a common practice.
for IBGP you should use the loopback interfaces to peer.
3-Do you have end-to-end IP connectivity in this network?
Reza
Giuseppe Larosa Thu, 12/03/2009 - 07:01
please post
sh ip bgp 192.168.1.8 taken on RB, the node that has an eBGP session with Ra
Hope to help
Giuseppe
