RVS4000 Multiple VLANs Not Routing
Dec 2nd, 2009
I have a couple RVS4000's and I use one of them as a router on a stick with two VLANs in it.
Two VLANs works fine.
However, when I add another VLAN, it will not route it.
I looked in the routing table and it doesn't show any routes for the new VLAN.
I can see the routes for the other two VLANs but my third VLAN is nonexistent.
The most I can get it to do is ping the routers VLAN IP interface.
I can't access the switches' interface on that VLAN or anything else on the new VLAN.
Is this a known problem?
Does this thing only route two VLANs?
Alejandro Gallego Thu, 12/03/2009 - 06:50
Need a little more info please.
Would this be an accurate topology for you?
CLOUD >> Gateway Router (GWR) >> RVS (L3) (as L3 Switch, nothing connected to WAN port) >> Switch (L2) >> Clients
IP addressing (LAN):
L3: V1
L2: V1 172.16.10.X/24
Need to know how you are connecting the RVS. If you do have a GWR do you also have a route for new network pointing back to the RVS?
FratianiD Thu, 12/03/2009 - 08:17
Thanks for the quick reply...
Here is what I'm working with now (currently works):
Cable Modem 1 ---> RVS4000 (Master) ---> Swtich (L3)
Cable Modem 2 ---> RVS4000 (No VLANs) ----> Switch (L3)
The Master RVS4000 routes all the VLANs (Trunk) and NAT/PAT Internet for the servers.
The Other RVS4000 is just running the default VLAN and routes NAT/PAT Internet for the clients.
The L3 switch is an SGE2010P and I distrubte the VLANs through this switch.
I also have a WAP4410N that is trunked to the Client VLAN right now.
IP Addressing:
RVS4000 (Master): (VLAN 1)
                    (VLAN 100)
RVS4000 (Clients): (VLAN 1 - Router is not aware of the VLANs)
Switch: (VLAN 1)
   (VLAN 100)
The problem is when I make another VLAN:
RVS4000 (Master): (VLAN 110)
Switch: (VLAN 110)
I am unable to communicate with the new network.
Nothing shows up in the RVS40000 (Master)'s routing table for the new network.
