LMS 3.2 Devices not selectable in RME
Dec 2nd, 2009
Running LMS 3.2 RME 4.3.1   when trying to do a software update or upgrade analysis under RME Software management I am not able to select any device in the Device selection window. I can put a tick in All devices checkbox but it doesn't actually select any devices. I can drill down to an individual device but cannot select it. no tick appears in the checkbox. Please assist
Joe Clarke Wed, 12/02/2009 - 22:13
This sounds like a package problem.  Can you post a screenshot illustrating this problem?
mburrell5 Thu, 12/03/2009 - 13:15
I had to reboot the server after installing some MS patches and it has come good!! To further explain the problem, when I had the Device Selection box up and ticked All devices it would still show 0 devices selected at the bottom whereas now it shows 631 devices selected which is correct
