Pix 7.2 to IOS VPN - replies not being decrypted?
Dec 2nd, 2009
I have an IOS router (12.4) that I am adding a VPN tunnel to.  There are other active tunnels on this router (both ezvpn, site-to-site and GRE).  Everything appears to be working on both sides regarding phase 1/phase 2 negotiation, but packets that are being send from the PIX to the IOS router, while being encrypted and encapsulated do not appear to be being decrypted on the IOS end.
I have spent many, many hours on trying to diagnose this and I am struggling - would appreciate any help.
Show crypto isakmp sa on the IOS shows (IPs changed for security):
1.1.1.1 2.2.2.2 QM_IDLE              4    0 ACTIVE
Show crypto ipsec sa on the IOS shows (IPs changed for security):
local  ident (addr/mask/prot/port): (10.13.39.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (172.16.50.0/255.255.255.0/0/0)
   current_peer 2.2.2.2 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 408, #pkts encrypt: 408, #pkts digest: 408
   #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 108, #recv errors 0
     local crypto endpt.: 1.1.1.1, remote crypto endpt.: 2.2.2.2
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/0
     current outbound spi: 0xBC3A7FC9(3157950409)
     inbound esp sas:
      spi: 0x2DF17FA(48175098)
        transform: esp-3des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 3003, flow_id: FPGA:3, crypto map: CustVPN
        sa timing: remaining key lifetime (k/sec): (4553489/2310)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 3004, flow_id: FPGA:4, crypto map: CustVPN
        sa timing: remaining key lifetime (k/sec): (4553463/2310)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
I am focusing in on the decapsulation/decryption and on why it is not happening.  Everything appears to be working on the PIX end.
show crypto isakmp sa on the PIX shows (IPs changed for security):
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: 1.1.1.1
    Type    : L2L             Role    : initiator
    Rekey   : no              State   : MM_ACTIVE
show crypto ipsec sa on the PIX shows (IPs changed for security):
Crypto map tag: outside_map, seq num: 120, local addr: 2.2.2.2
      access-list outside_cryptomap_120 permit ip 172.16.50.0 255.255.255.0 10.13.39.0 255.255.255.0
      local ident (addr/mask/prot/port): (172.16.50.0/255.255.255.0/0/0)
      remote ident (addr/mask/prot/port): (10.13.39.0/255.255.255.0/0/0)
      current_peer: 1.1.1.1
      #pkts encaps: 1030, #pkts encrypt: 1030, #pkts digest: 1030
      #pkts decaps: 322, #pkts decrypt: 322, #pkts verify: 322
      #pkts not compressed: 1030, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 2.2.2.2, remote crypto endpt.: 1.1.1.1
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: 02DF17FA
    inbound esp sas:
      spi: 0xBC3A7FC9 (3157950409)
         transform: esp-3des esp-sha-hmac none
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 36, crypto-map: outside_map
         sa timing: remaining key lifetime (kB/sec): (4274981/1824)
         IV size: 8 bytes
    outbound esp sas:
      spi: 0x02DF17FA (48175098)
         sa timing: remaining key lifetime (kB/sec): (4274939/1824)
         IV size: 8 bytes
Everything seems ok to me but the IOS is not decrypting.  The other tunnels on the system are working fine.  Debugs do not show any errors.
foxx0171 Fri, 12/04/2009 - 07:52
Ended up putting an encrypted GRE tunnel in place with an IOS <--> IOS VPN.  Ended up with the same problem.  Was something on the ASA end that was dropping packets sent to the IOS.
What version of IOS is on the VPN router.. I had a very similar issue
I have 2 vpn routers with slightly different revs of the IOS one will terminate a tunnel to 7.2 and pass traffic without any issue the other will terminate the tunnel but refuse to pass traffic.
Configurations are identical minus the ip addresses of course.
Related Content
