Clean Access Web Agent
Dec 2nd, 2009
Hi All,
          I know ADSSO is not applicable for Web Agent.  But would it be possible to choose an authentication provider using Web Agent?  The scenario happens when there is a new PC that needs to connect to the network to install Clean Access Agent, client wants to connect not through localDB but through AD authentication.  Thanks.
IT_Data_CorporateNet Wed, 12/02/2009 - 23:43
Hi Dan,
It is possible to have a different Provider. If you go to User Management > Auth Servers you will see a place to create a new Provider. If You have a Cisco ACS server integrated with AD you can configure Radius Authentication on your NAC using that ACS Server. I'm using it for web users and it is working fine.
