Device Pools - Roaming Sensitive Settings
Answered Question
Dec 2nd, 2009
Hello:
I have I hope a simple question about the "Roaming Sensitive Settings" in the Device Pools (we're running Communications Manager 6.1(2)).
I believe I understand that the "Roaming Sensitive Settings" are used to enforce specific options (such as an MRGL) upon a device when its roaming (away from its home location).  In other words, I believe that if I set an MRGL in the "Roaming Sensitive Settings" no matter where the IP phone roams to, it will use the MRGL I've specified (not necessarily a good thing) in the Device Pool (if I don't override it on the IP phone's configuration page).
But if the IP phone is in its home location, and the IP phone's configuration has a value of <None> for Media Resource Group List parameter will the phone use the MRGL set in it's Device Pool's "Roaming Sensitive Settings".  OR are the values in the Device Pool's "Roaming Sensitive Settings" only used when the phone is roaming?
Thanks for the clarification.
Correct Answer by Paul Reck about 7 years 7 months ago
Hi Ken,
the roaming sensitive settings are applied even if the phone is in it's home location.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fsdevmob.html#wp1088546
regards,
Paul
Overall Rating: 5 (1 ratings)
