Favicon for Clientless VPN Portals?
Dec 3rd, 2009
Is there a way to set a favicon without going into full customization? I supect that since full customization allows you to to provide full HTML it would work, however you then have to recreate all of the layout as well and maintain it.
dbgreekas Sat, 12/05/2009 - 00:15
One solution... .Upload a favicon.ico file to /+CSCOU+/ so it can be accessed without login
Then insert the following after your Title Pain Text on each of the main customization areas login, portal, and logout.
It appears you can inject HTML into almost any of the visible custom text fields.
