Easy VPN on ASA
Answered Question
Dec 3rd, 2009
Dear all,
I configured easy VPN on my ASA, but, when i type the following command, it gives  me this error as shown:
SA-Gate(config)# crypto ipsec transform-set myset esp-3des esp-md5-hmac
The 3DES/AES algorithms require a VPN-3DES-AES activation key.
ASA-Gate(config)# crypto dynamic-map dmap 100 set transform-set myset
ERROR: transform set with tag "myset" does not exist.
So, this issue concerning Licensed features on ASA and if so, what is all required to complete the easy VPN configuration.
N.B.: sh version of ASA is attached.
Correct Answer by Pedro Ivo Santo... about 7 years 5 months ago
Hi Ahmed,
Hope you are doing fine!
Actually your activation key (license) only allows you use DES encryption level (not 3DES or AES).
So when configuring the transform set. You have to set ecryption as DES:
"crypto ipsec transform-set myset esp-des esp-md5-hmac"
Otherwise, you ned a license upgrade to enable 3DES/AES. Check this link:
http://www.cisco.com/en/US/docs/security/asa/asa80/getting_started/asa5500/quick/guide/DESlic.html
Hope this helps you.
Cheers,
Pedro
Overall Rating: 5 (1 ratings)
Correct Answer
Pedro Ivo Santo... Mon, 12/07/2009 - 10:21
  • Cisco Employee,
  • Events Top Contributors,
    2013
Hi Ahmed,
Cheers,
Pedro
Ahmed Yassin Tue, 12/08/2009 - 02:34
Thx a lot for your suggestion, and it is
worked well with me.
But, if you please, what is the exact difference bet. 3DES & DES.
Pedro Ivo Santo... Tue, 12/08/2009 - 03:46
  • Cisco Employee,
    2013
Hi Ahmed,
The difference between them is the level of strength of the encryption algorythm. 3DES uses 3 encryption keys (created by the algorythm) while DES uses only one. In practical terms, 3DES has a 3 times longer key to encrypt data than DES, what makes 3DES a stronger method.
Cheers,
Pedro
