automatic configuration backup
Dec 3rd, 2009
I want to take automatic configuration backup of a cisco 2950 switch having IOS image-c2950-i6k2l2q4-mz.121-22.EA13.bin to a remote tftp server.
please suggest what are the commands to use on the switch.
If this IOS version is not supported,then which one should be upgraded.
Overall Rating: 3 (1 ratings)
Edison Ortiz Thu, 12/03/2009 - 13:17
There is no automation on the 2950 switch under any IOS level.
You will need a NMS tool to perform the running-configuration transfer to the TFTP server.
You can instruct the NMS tool to execute the command highlighted in the documentation:
With newer hardware and IOS releases, you can automate internal task in IOS by using EEM.
snickered Thu, 12/03/2009 - 15:26
There's also a sweet tool out there called RANCID that will download your config at an interval you specify, run a diff comparing it to the config downloaded previously and keep it in a CVS tree.  It also e-mails you the changes at the interval you specify.  I couldn't live without it.  It's a package in OpenBSD and I'm pretty sure it's in the ports tree of FreeBSD as well.
