VPN Split Tunneling Unsuccessful
Answered Question
Dec 3rd, 2009
I am working on creating a split tunnel to work with a test vpn group profile. We have an external proxy service that slows users down when they are VPN'd in because their web traffic then goes through us. My goal is to configure only private IP's to come through the tunnel, any requests to public IP's should go straight out the users internet connection and not VPN.
I have created an ACL on the firewall that includes all of the standard private 192, 172, and 10 scope ips and I set the vpn group profile to only tunnel based on those IP addresses.
However when I perform this testing with the Cisco AnyConnect SSL VPN client and I look at the routing tab, it still shows 0.0.0.0 0.0.0.0 to go through the VPN tunnel and isn't splitting the traffic. I have not tested this on the orginal Cisco VPN client yet.
The configuration guides that I have looked seems to show I am setting it up correctly but am I missing anything?
Correct Answer by busterswt about 7 years 7 months ago
Try swapping the source and destination in that ACL, then reconnect via client VPN and see if that makes a difference. You might also try specifying the local pool network used for the client VPN instead of 'any'.
Overall Rating: 5 (2 ratings)
busterswt Thu, 12/03/2009 - 17:04
  • Bronze, 100 points or more
Is there any chance you can post your ACLs, tunnel groups and group policies here?
James
ericn8484_2 Fri, 12/04/2009 - 05:20
Sure, here is my test group configuration:
object-group network DM_INLINE_NETWORK_1
network-object 10.0.0.0 255.0.0.0
network-object 172.16.0.0 255.240.0.0
network-object 192.168.0.0 255.255.0.0
group-policy TESTVPN internal
group-policy TESTVPN attributes
wins-server value 172.16.9.221 172.16.9.222
dns-server value 172.16.9.221 172.16.9.222
vpn-idle-timeout 600
vpn-session-timeout 600
vpn-tunnel-protocol IPSec svc webvpn
ipsec-udp enable
ipsec-udp-port 10000
split-tunnel-policy tunnelspecified
split-tunnel-network-list value TESTVPN
secure-unit-authentication disable
user-authentication disable
nem enable
tunnel-group TESTVPN type remote-access
tunnel-group TESTVPN general-attributes
address-pool VPN_Pool
authentication-server-group VPN_Users
default-group-policy TESTVPN
dhcp-server 10.0.0.1
tunnel-group TESTVPN webvpn-attributes
group-alias TestVPN enable
tunnel-group TESTVPN ipsec-attributes
pre-shared-key *
busterswt Fri, 12/04/2009 - 05:30
Do you have an access list named 'TESTVPN', and does it only include the networks you want traversing through the tunnel?
- James
ericn8484_2 Fri, 12/04/2009 - 05:34
Ops, I apologize that I missed that part, the ACL created looks like:
access-list TESTVPN extended permit ip any object-group DM_INLINE_NETWORK_1
Which points to this:
I did this via ADSM
Correct Answer
busterswt Fri, 12/04/2009 - 05:56
ericn8484_2 Fri, 12/04/2009 - 06:06
Great tips, I will try those suggestions later this afternoon.
Thanks!
