DMVPN with dual ISP link at branch office
Dec 3rd, 2009
Can not get failover to work correctly with dual ISP links at branch office, I have attached a little drawing of what Im trying to get to work.
If I configure OSPF then the failover works fine, but as soon as I enable IPSEC to the tunnels, then it will only failover once, and not back again, when the primary is working again.
Is there anyone there is having a working configuration, it is fine if it is at the headend the dual links are, because it should be the same setup.
I'm willing to use, RIPv2 (preferred), EIGRP, OSPF, TRACKING, IP SLA or what ever, just I can get it to work........
