EBGP neigbor issue
Answered Question
Hi !
I'm currently working on my BSCI certification Exam, I had setup the attach lab for my understanding about BGP. I don't know why the my router in different AS cannot enter in establish states. The same setup exist between PXR1 and PXR2 router both are member in same AS those are able to go in established states. I try to changed BBR2 to the AS 65001 and change neighbor statement in the PXR1 router, after that those router are going into establish states.... I had used extended ping to reach each router loopback interface with source address the loopback interface to check if my problem is an router issue, each router can ping each of there supposed neigbor router. But only router are in the same AS will be enter in the establish states.
I would like to know why thoses routers cannot be going in establish states (all of then are kept in idle states)
Correct Answer by Giuseppe Larosa about 7 years 7 months ago
Hello Christian,
eBGP sessions have a default TTL of 1
neighbor 192.168.200.4 remote-as 64998
neighbor 192.168.200.4 update-source Loopback0
you need to add
neigh 192.168.200.4 ebgp-multihop 2
iBGP sessions default to TTL 255 in BGP messages and don't need the above command
do the same on both ends
Hope to help
Giuseppe
Overall Rating: 5 (6 ratings)
Correct Answer
Giuseppe Larosa Thu, 12/03/2009 - 06:51
  • Hall of Fame,
    Founding Member
Hello Christian,
you need to add
Hope to help
Giuseppe
Laurent Aubert Thu, 12/03/2009 - 07:04
  • Cisco Employee,
By default, the router assume the eBGP peer is directly connected so the TTL is set to 1. To change this behavior, you need to add the following configuration:
neighbor x.x.x.x ebgp-multihop
http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_n1g.html#wp1037550
or even better  if your version support it:
neighbor x.x.x.x disable-connected-check
http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_n1g.html#wp1079915
Laurent.
