12-03-2009 07:33 AM - edited 03-06-2019 08:49 AM
Hi Community,
i have the follow problem:
Cisco-2800 (AUX) ---> analog-modem A <----> analog-modem B ---> serial-port (VT100)
As shown above, the Cisco connect to the modem A and be elected to the modem B.
Once there is a dial-up connection should to connect to a serial console.
So far, already works as follow:
An IP from the LAN section of the router connect to the Dial Interface
constructed and selected the appropriate telephone number for the
modem B. Unfortunately it didn't comes a prompt for the serial device.
To cut a long story short: Here's the config:
Router#show run
Building configuration...
Current configuration : 2041 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$u3xd$iwBXXQtuw4FHAYvdEhmk21
enable password XXXXXX
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
voice-card 0
no dspfarm
chat-script DD ABORT ERROR ABORT BUSY "" "AT Z" OK "ATDT \T" TIMEOUT 30 CONNECT \c
chat-script Sound "" ATM1
modemcap entry MyTest:MSC=&F&C1&D2S0=1H0
username xxxxx password xxxxxxx
archive
log config
hidekeys
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
ip address 172.16.0.1 255.255.0.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
interface Async1
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode interactive
interface Dialer1
ip address 172.19.1.1 255.255.255.252
encapsulation ppp
dialer pool 1
dialer idle-timeout 100
dialer string 52
dialer-group 1
interface Dialer2
ip address 172.20.1.1 255.255.255.252
encapsulation ppp
dialer pool 1
dialer string 43
dialer-group 1
ip forward-protocol nd
ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
control-plane
line con 0
modem autoconfigure discovery
line aux 0
script connection DD
login local
modem InOut
modem autoconfigure type MyTest
no exec
transport input all
transport output pad telnet rlogin udptn v120
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
password t
logging synchronous
login local
scheduler allocate 20000 1000
end
12-07-2009 12:56 AM
please provide more
information of VT100,also a router?
And what is the application of the a IP.
Keisikka
12-07-2009 02:50 AM
Hi keisikka@163.com,
The serial-device is a normal serial-device without ip-address. I can connect to it with Putty over Serial.
But now we want make a connection over the AUX-Port with modem connection.
When someone (in the LAN) make a telnet session to a IP-address, the router will link it to a telephonenumber
and open a serial-session. That's the theory.
THX Daniel
12-08-2009 10:08 PM
In my understanding.
Telnet is a application depends on tcp/ip, so there shold has a connection betweem hosts.
However, serial shold has a connection over RS232.
If I mistake,please inform me.
THX
Keisikka
12-09-2009 04:52 AM
Hello Daniel,
in configuring an IOS router to act as a terminal server we can associate the usage of an async line to a specific host
you need to get the AUX line number from the output of sh line, it is typically 1.
int loop1
ip address 10.10.10.1 255.255.255.255
the TCP port to be used for reverse telnet is 2000+ line#
example:
ip host vt100 10.10.10.1 2001
Your case is different.
You need a L3 device on the other end to be able to use DDR dial out as explained here:
https://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094579.shtml
if you haven't a L3 IP device on the other end, you should look at terminal server and your trigger is the telnet to the host as defined above
Hope to help
Giuseppe
