MAC Address discovery issue
Answered Question
Dec 3rd, 2009
  • Blue, 1500 points or more
I have a
Catalyst 4506 switch running IOS cat4000-i9s-mz12-25.EWA4.bin
The question I have is....
I have a Cisco Phone that is connected to an interface and a PC that is connected to the Phone. The Link speed should be 1000/full. When I run the command show mac-add dyn   I do not see any MAC Address entries for the phone or the PC on that port and it is only running at 100/full but I do have network connectivity for both the PC and Phone.. On other ports I can see the MAC address for both the Phone and PC. What could the issue be?
Mike
Correct Answer by Edison Ortiz about 7 years 3 months ago
Auto/Auto at the IP Phone and switchport should negotiate to 1Gb/FD if both link partners support such speed/duplex setting.
If the negotiation did not occur and both are set to Auto/Auto, replace the cable at both ends.
Also, try connecting the phone to another switchport.
Edison
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Thu, 12/03/2009 - 13:03
  • Hall of Fame,
    Founding Member
Edison
burleyman Fri, 02/12/2010 - 07:24
I am going through some of my post that I have resolved and rating them
and posting they were solved.
Thanks Edison for your help.
Mike
Kevin Dorrell Fri, 02/12/2010 - 07:46
  • Green, 3000 points or more
A thought about the lack of entries in show mac-addr dyn ... do you have port security on that port?  Secure addresses are regarded as static rather than dynamic.
Kevin Dorrell
Luxembourg
burleyman Fri, 02/12/2010 - 07:59
I did think about that but I do not have security on the ports. I did have them replace the cable even though they said they did already and that seemed to resolve the issue.
Mike
