ASA5505 Licences - Security Plus licence and SSL licence
Dec 3rd, 2009
A bit confused by the licencing of the ASA5505 (ASA5000 series) products.
There are 2 parts to my question. The first is where I need to get the best ordering option for a new ASA5505, where as the second is to
understand what I need to order for an existing ASA5505.
Q1. I am looking at a new ASA5505 to support up to 25 SSL connections, so I am assuming that I need to purchase ASA5505-SSL25-K9
which gives me the hardware and the licence for the 25 SSL VPN connections.
However, I need DMZ support and support for more than 3 Vlans.
Does this product code support this or do I need to order the Security Plus licence on top?
What is the licence product code? I have seen the product code, ASA5505-SEC-PL, which I understand gives this support.
I suppose I need to ask the question but I assume that this is possible.
So do I order ASA5505-SSL25-K9 + ASA5505-SEC-PL?
Q2. I already have a firewall purchased under part number ASA5505-SEC-BUN-K9. Do I order ASA5500-SSL-25 to add the 25 SSL VPN licence
to the existing product.
Or maybe for the new ASA5505, I order the same as in Q2. (i.e. ASA5505-SEC-BUN-K9 + ASA5500-SSL-25).
Not sure of the benefits of either option.
Thanks in advance.
Collin Clark Fri, 12/04/2009 - 09:08
  • Purple, 4500 points or more
1. You are correct, you need ASA5505-SSL25-K9 and ASA5505-SEC-PL.
2. You can just purchase the ASA5500-SSL-25.
There is no advantage of purchasing one bundle over another (price or feature).
Hope it helps.
