I need to write an application that will access the router remotely and import the exp config file. Is there a SDK or web request on the router or anything I can do to accomplish this? We have hundreds of routers to go through an production line to import our predefined settings before sending them to the field and importing them manually is not desired.
Looking into documentation for this for you, but doubt we have such a thing for this product. However, maybe you can look at a trace and build your own HTTP message based on what you see happening when you do actions on the router GUI....
