BGP multihop delayed:Why loopback network is not learned?
Answered Question
Dec 3rd, 2009
Hi folks, very simple setup to confirm some basic concepts. R1 and R2 are connected via interfaces as shown below. Then I advertise the loopback0 via BGP network statement. My understanding is that this is iBGP, so the eBGP multihop command should not apply. Next-hop-self should not be relevant because routers are on same BGP AS.
So my question is, why these loopback networks are not learned by the neighbor routers? I am wondering if this could be a glitch or I am msising something.
R1 lo0=150.4.1.1/24              R2 lo0  150.4.2.2/24
R1 f1/0=155.4.0.1/24-------------R2 f1/0 155.4.0.2/24
BGP debugging is on
R1#
00:30:23: BGP: 150.4.2.2 multihop open delayed 15904ms (no route)
R1#show run | b bgp
router bgp 100
no synchronization
bgp log-neighbor-changes
network 150.4.1.0 mask 255.255.255.0  <== I advertise the loopback0 of R1 here. I do not understand how come R2 will not learn this route.
neighbor 150.4.2.2 remote-as 100
neighbor 150.4.2.2 update-source Loopback0
no auto-summary
R1#show ip route 150.4.2.0
% Subnet not in table
R1#show ip bgp
BGP table version is 2, local router ID is 150.4.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 150.4.1.0/24     0.0.0.0                  0         32768 i
R1#show ip route
(supressed)
Gateway of last resort is not set
     155.4.0.0/24 is subnetted, 1 subnets
C       155.4.0.0 is directly connected, FastEthernet1/0
     150.4.0.0/24 is subnetted, 1 subnets
C       150.4.1.0 is directly connected, Loopback0
R1#show ip bgp summ
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
150.4.2.2       4   100       0       0        0    0    0 never    Active  <== R2 is a neighbor OK.
R1#
R1#show run int lo 0
Building configuration...
Current configuration : 63 bytes
interface Loopback0
ip address 150.4.1.1 255.255.255.0
end
R1#
R2#show run | b bgp
router bgp 100
no synchronization
network 150.4.2.0 mask 255.255.255.0
neighbor 150.4.1.1 remote-as 100
neighbor 150.4.1.1 update-source Loopback0
no auto-summary
R2#show ip bgp
BGP table version is 2, local router ID is 150.4.2.2
*> 150.4.2.0/24     0.0.0.0                  0         32768 i
R2#sh ip route
(supressed)
C       150.4.2.0 is directly connected, Loopback0
#show ip bgp summ
150.4.1.1       4   100       0       0        0    0    0 never
R2#
interface Loopback0
ip address 150.4.2.2 255.255.255.0
end
Correct Answer by Reza Sharifi about 7 years 3 months ago
So it seems that when I have loopbacks involved I should plan to advertise them via IGP before attempting to establish the neighbor relationship using such loopbacks (or of course use other method such static route or connect using interfaces, etc).
Yes, that is a good idea.  you should be able to ping each peering loopback address before even get the BGP going. This way you know your IP connectivity is good before you move on to configure BGP.  You can use static route or dynamic routing protocol to accomplish this
Reza
Correct Answer by Jon Marshall about 7 years 3 months ago
news2010a wrote:
Interesting that in this case the routes were not passed to
each other router via iBGP. The BGP network statement is there
advertising such loopback network on the respective routers. The respective loopback network is a directly connected loopback interface (that means it is in the ip routing table of the respective router). Yet it did not learn via iBGP. Very interesting behavior.
Because when you use the update source loopback command that means that source address of the packet is set to the loopback.
So from R2s perspective, it receives a BGP open packet with a source address of the 150.4.1.1. Note that this is before any routes are exchanged, this is to setup a BGP session so routes can be exchanged. But R2 doesn't know about this network because there is no IGP running so it cannot establish a BGP session.
So the issue is not so much that it was not learned via IBGP it was that it never got to that stage of exchanging routes because a BGP session was never established.
Jon
Overall Rating: 5 (1 ratings)
marpina Thu, 12/03/2009 - 11:45
  • Cisco Employee,
It seems the BGP session is still down. We have 2 possibles options here.
on this link include details about the neighbor is on Active status means
no routes to the neighbor address or is not reachable.
https://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093fb8.shtml
1. used the physical interface IP address on the neighbor statement and remove "neighbor x.x.x.x  update-source Loopback0"
on each router.
2. If works, then enabled  any IGP (as ospf) or add static routes in order to be reach the loopback of each routers.
This link have further scenarios, maybe help you.
Best regards
Marcelino
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml
Reza Sharifi Thu, 12/03/2009 - 11:37
  • Cisco Designated VIP,
    2017 LAN
Active is not good. your neighbor relationship has not been established.
Looking at your config you are peering
R1
and R2
In the above scenario, the address for each site has to be on the same subnet
see below
R1
and R2
neighbor 150.4.2.1 remote-as 100
Reza
Jon Marshall Thu, 12/03/2009 - 11:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
BGP debugging is on
R1#
R1#show run | b bgp
router bgp 100
no synchronization
no auto-summary
R1#show ip bgp
R1#show ip route
(supressed)
R1#show ip bgp summ
R1#
interface Loopback0
end
R1#
R2#show run | b bgp
router bgp 100
no synchronization
no auto-summary
R2#show ip bgp
R2#sh ip route
(supressed)
#show ip bgp summ
R2#
interface Loopback0
end
Marlon
The reason it is not working is that R1 does not know how to get to the loopback of R2 and vice-versa.
So either run an IGP or
R1
ip route 150.4.2.2 255.255.255.255 155.4.0.2
R2
ip route 150.4.1.1 255.255.255.255 155.4.0.1
Jon
news2010a Thu, 12/03/2009 - 12:11
Correct Answer
Reza Sharifi Thu, 12/03/2009 - 12:17
    2017 LAN
Reza
Correct Answer
Jon Marshall Thu, 12/03/2009 - 12:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
