Help with Port Forwarding from Outside Address
Answered Question
Dec 3rd, 2009
Can someone point me to info on port forwarding from an external address to an internal address. This firewall has a DMZ, but the machine I want to port forward to does not sit in the DMZ. All attempts to solve have lead to my machines in the DMZ not working.
Correct Answer by resoares about 7 years 2 months ago
Ok, have you already checked all ACLs for inside and outside directions?
Be aware that an ACL must allow the traffic comes from Internet to DMZ servers.
Br,
Overall Rating: 5 (2 ratings)
resoares Thu, 12/03/2009 - 12:47
Try this command below:
static (inside,outside) tcp 1.1.1.1 www 2.2.2.2 www netmask 255.255.255.255
where 1.1.1.1 = it is your public ip address and 2.2.2.2 it is your internal one ( RFC 1918 ). In this example, the firewall is performing a static PAT for HTTP service. In this case, the reachable ip address for the Internet will be 2.2.2.2
Br,
resoares Thu, 12/03/2009 - 12:48
Sorry, the ip will be 1.1.1.1 to be reachable by Internet
chuckmccants Thu, 12/03/2009 - 13:12
So are you saying:
static (inside,outside) tcp External-IP www Internal-IP www netmask 255.255.255.255
Correct Answer
resoares Fri, 12/04/2009 - 10:12
Br,
chuckmccants Fri, 12/04/2009 - 10:47
Yes,  realize that. But, this is not a DMZ host, it is one that sits on the inside network.
Correct Answer
resoares Fri, 12/04/2009 - 10:53
chuckmccants Sat, 12/05/2009 - 08:44
Got it. I added:
access-list Inside_access_out extended permit tcp any host 192.168.14.252 eq www
access-list Inside_access_out extended permit tcp host 192.168.14.252 eq www any
and everything finally worked.
Thanks again for your help.
Chuck
Related Content
