12-03-2009 04:01 PM
Hi folks,
I was running a little lab where I had an mpls te tunnel running fine from one router located at the border of the network to the other, I was using ISIS as the IGP. Everything was fine untill I added BGP to the lab and suddenly the tunnel turn down. I want to know if I got to add an additional configuration to my PE routers to succesfully bring up my tunnel like before. My tunnel's explicits path were LSR-PE2 and LSR PE1. My topology looks like this.
LSR
eBGP / \ eBGP
ASx ------------ PE1 ----------------- PE2--------------ASy
iBGP
Francis.
12-03-2009 06:01 PM
Please provide config of your PE1 and PE2
Roman
ieMentor
12-04-2009 04:42 AM
Here I leave the configurations and I correct myself about the network topology, I added a pic about the exact topology too. The tunnel is built PE1-R1-R3.
PE1 - R0
clns routing
mpls label protocol ldp
mpls traffic-eng tunnels
interface Loopback0
ip address 10.201.0.0 255.255.255.255
ip router isis
interface Tunnel0
ip unnumbered Loopback0
tunnel destination 10.201.0.3
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng priority 5 5
tunnel mpls traffic-eng bandwidth 1000
tunnel mpls traffic-eng path-option 10 explicit name te
no routing dynamic
interface FastEthernet0/0
bandwidth 100000
ip address 10.200.0.1 255.255.255.252
ip router isis
duplex auto
speed auto
mpls ip
ip rsvp bandwidth 75000
ip rsvp resource-provider none
interface FastEthernet1/0
bandwidth 100000
ip address 10.200.0.5 255.255.255.252
ip router isis
duplex auto
speed auto
mpls ip
ip rsvp bandwidth 85000
interface FastEthernet2/0
ip address 190.80.239.1 255.255.255.252
duplex auto
speed auto
router isis
net 49.0123.0000.0000.0000.00
is-type level-1
metric-style wide
mpls traffic-eng router-id Loopback0
mpls traffic-eng level-1
router bgp 6400
no synchronization
bgp log-neighbor-changes
network 190.80.239.0 mask 255.255.255.252
neighbor 10.201.0.4 remote-as 6400
neighbor 10.201.0.4 password cisco
neighbor 10.201.0.4 update-source Loopback0
neighbor 190.80.239.2 remote-as 1630
neighbor 190.80.239.2 password cisco
no auto-summary
ip explicit-path name te enable
next-address 10.201.0.1
next-address 10.201.0.3
mpls ldp router-id Loopback0
LSR- R1
clns routing
interface Loopback0
ip address 10.201.0.1 255.255.255.255
ip router isis
bandwidth 100000
ip address 10.200.0.6 255.255.255.252
ip router isis
duplex auto
speed auto
mpls ip
mpls mtu 1508
interface Serial1/0
bandwidth 1500
ip address 10.200.0.9 255.255.255.252
ip router isis
encapsulation ppp
mpls ip
serial restart-delay 0
ip rsvp bandwidth 1200
interface Ethernet2/0
bandwidth 10000
ip address 10.200.0.13 255.255.255.252
ip router isis
full-duplex
mpls ip
mpls mtu 1508
router isis
net 49.0123.0000.0000.0001.00
is-type level-1
metric-style wide
LSR-R3
ip cef
no ip domain lookup
interface Loopback0
ip address 10.201.0.3 255.255.255.255
ip router isis
interface Tunnel0
tunnel destination 10.201.0.0
no routing dynamic
bandwidth 100000
ip address 10.200.0.2 255.255.255.252
ip router isis
duplex auto
speed auto
mpls ip
interface Serial1/0
bandwidth 1500
ip address 10.200.0.10 255.255.255.252
ip router isis
encapsulation ppp
mpls ip
isis metric 1677214
bandwidth 10000
ip address 10.200.0.14 255.255.255.252
ip router isis
full-duplex
mpls ip
interface FastEthernet3/0
bandwidth 100000
ip address 10.200.0.17 255.255.255.252
ip router isis
duplex auto
speed auto
mpls ip
isis metric 1677214
router isis
net 49.0123.0000.0000.0003.00
is-type level-1
metric-style wide
next-address 10.200.0.13
next-address 10.201.0.0
PE2- R4
ip cef
no ip domain lookup
clns routing
interface Loopback0
ip address 10.201.0.4 255.255.255.255
ip router isis
bandwidth 10000
ip address 10.200.0.18 255.255.255.252
ip router isis
duplex auto
speed auto
mpls ip
ip address 190.80.239.5 255.255.255.252
duplex auto
speed auto
router isis
net 49.0123.0000.0000.0004.00
is-type level-1
metric-style wide
router bgp 6400
no synchronization
network 190.80.239.4 mask 255.255.255.252
neighbor 10.201.0.0 remote-as 6400
neighbor 10.201.0.0 password cisco
neighbor 10.201.0.0 update-source Loopback0
neighbor 190.80.239.6 remote-as 36256
neighbor 190.80.239.6 password cisco
no auto-summary
12-04-2009 10:14 AM
Hello Francis,
what happens if you use a dynamic path instead of the explicit path?
you can check with sh mpls traffic-eng tunnel 0 to see the reason why RSVP TE failed.
I remember setting up explicit paths using IP address on physical RSVP enabled interfaces, not the loopback interfaces IP addresses
Hope to help
Giuseppe
12-04-2009 11:48 AM
Hi Guislar,
I had tested using dynamic path and it's still the same.
About setting up explicit paths using IP loopbacks interfaces instead of physical RSVP enabled interfaces. I'm actually reading the book called "Traffic Engineering with MPLS" and in the book I did read that you can build TE tunnels using the TE Router-Id accros the explicith path instead of using the IP address on physical RSVP enabled interfaces, and It says that you can specify the interface in case that you have a multiple links connecting two routers and you want that you traffic use a link insted of other (I don't know if It is a mistake in the book). But anyways, I'll do it like that because I didn't test using the ip of the physical interfaces, but I as I said I was ok just untill BGP came to the scene.
Francis
12-04-2009 03:22 PM
Hi Francis,
You are right- you can specify IP addresses of Loopback interfaces in Explicit-paths as long as they are reachable; this makes it easier to specify a path.
Anyways, you are trying to create an MPLS TE tunnel from a PE-router with tail-end router as a P-router. You need to make sure two things are done-
1) LDP is enabled on MPLS TE tunnel i.e. "mpls ip" command under Tunnel interface on PE-router.
2) following config on P-router-
mpls ldp discovery targeted-hello accept from ACCEPT_FROM_SOURCE
ip access-list extended ACCEPT_FROM_SOURCE
permit ip host
This will make sure the P router accepts the tunnel connection from PE router.
Let us know how you went after this.
HTH.
Amit.
12-04-2009 07:11 PM
BGP/MP-BGP should be configured before MPLS and MPLS-TE. This is to ensure that full NLRI is met and therefore your LSP's can be built and then manipulated with TE.
I believe in a modular approach when configuring such features or else you will be going back to your configs and adding configurations that you fell may solve your issue, but if not consistantly across the network devices can and will cause other issues that will be harder to troubleshoot.
I suggest you take off TE and MPLS LDP peering, configure BGP/MP-BGP and then put MPLS and TE back on.
Joe.
12-09-2009 05:37 AM
Any update on this?
I also noticed that you're not setting the bgp router-id, you should definately do that. But like I said in my last post, take off MPLS and TE, put BGP on, verify thats working and routes passing, then put MPLS and TE back on.
Joe.
