vacmContextName OID dosent return SNMP context's
Dec 3rd, 2009
Hi All,
Can anyone help me in solving the following SNMP issue,
   I tried to get the SNMP contexts configured in the device through vacmContextName OID from SNMP-VACM-MIB, but the device responded nothing for the same. But the CLI command 'sh snmp context' returns data perfectly. So do we need to configure something to get these details through SNMP ?
Thanks in Advance for your replies.
Farrukh Haroon Tue, 12/15/2009 - 10:06
If the other SNMP MIBS are getting populated, than there is nothing to configure on the firewall (i.e. SNMP polling is working in general).
Your particular MIB (or that OID) is most probably not supported on the firewall. Check the release notes and  firewall documentation for the support information.I found the following link, please check it for support, I think only specific parts/tables of the concerned MIB are supported:;jsessionid=EDB42ABEEA7E9BE0C157648C922E18A3.node0#SNMPVACMMIB
