LMS 3.2 /DFM 3.2.0 - DDV report a unknown status on 45xx series
Answered Question
Dec 4th, 2009
Hello Dears all,
a DDV report has send a unknown status while the package has been loaded on both kind of routers.
- 4506
- 4507r
The status has reported is "Other" . I have attached the snapshot . It concerns Fan and Power Supply.
The test made , is , as the Power supply are implemented with redundancy, to power off one of the both.
I have made him  a snmp walk on equipements, for get the exact mib description.
1.3.6.1.4.1.9.1.876 and .502 have been  supported. The device package is the Cat4000IOS version 7.2
My end user has experimented this default on anothers machines.
Does the bug CSCsz77616 can be applied for that ?
Is the DDV.Log and Interact.log could be shows us something ?
Correct Answer by Joe Clarke about 7 years 4 months ago
EMC is the vendor who writes the polling engine for DFM.  We OEM the Smarts InCharge engine as the underlying components of DFM.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 12/04/2009 - 14:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Device packages and sysObjectIDs don;t have any bearing on this issue.  DFM is reporting that the status of this PS is "OTHER" which is most likely what is getting reported by the device.  Post an SNMP Walk of the ciscoEnvMonMIB branch.
richard.tetu Mon, 12/07/2009 - 05:30
Hello, Joe
The SNMP walk has been launched.
On a 4506 type:
SNMP Walk Output
.1.3.6.1.4.1.9.9.13
CISCO-ENVMON-MIB::ciscoEnvMonPresent.0 = INTEGER: cat4000(9)
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureStatusDescr.1 = STRING: Chassis Temperature Sensor
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureStatusValue.1 = Gauge32: 36 degrees Celsius
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureThreshold.1 = INTEGER: 95 degrees Celsius
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureLastShutdown.1 = INTEGER: 0 degrees Celsius
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureState.1 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonFanStatusDescr.1 = STRING: Chassis Fan Tray 1
CISCO-ENVMON-MIB::ciscoEnvMonFanStatusDescr.2 = STRING: Power Supply 1 Fan
CISCO-ENVMON-MIB::ciscoEnvMonFanStatusDescr.3 = STRING: Power Supply 2 Fan
CISCO-ENVMON-MIB::ciscoEnvMonFanState.1 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonFanState.2 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonFanState.3 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplyStatusDescr.1 = STRING: Power Supply 1
CISCO-ENVMON-MIB::ciscoEnvMonSupplyStatusDescr.2 = STRING: Power Supply 2
CISCO-ENVMON-MIB::ciscoEnvMonSupplyState.1 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplyState.2 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplySource.1 = INTEGER: ac(2)
CISCO-ENVMON-MIB::ciscoEnvMonSupplySource.2 = INTEGER: ac(2)
CISCO-ENVMON-MIB::ciscoEnvMonAlarmContacts.0 = BITS: 00
CISCO-ENVMON-MIB::ciscoEnvMonEnableShutdownNotification.0 = INTEGER: false(2)
CISCO-ENVMON-MIB::ciscoEnvMonEnableTemperatureNotification.0 = INTEGER: false(2)
CISCO-ENVMON-MIB::ciscoEnvMonEnableFanNotification.0 = INTEGER: false(2)
CISCO-ENVMON-MIB::ciscoEnvMonEnableRedundantSupplyNotification.0 = INTEGER: false(2)
CISCO-ENVMON-MIB::ciscoEnvMonEnableStatChangeNotif.0 = INTEGER: false(2)
On 4507R-E equipement
The following is a SNMP walk of device 172.xx.xx.xx starting from .1.3.6.1.4.1.9.9.13
SNMP Walk Output
.1.3.6.1.4.1.9.9.13
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureStatusDescr.21 = STRING: Chassis Temperature Sensor
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureStatusValue.21 = Gauge32: 35 degrees Celsius
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureThreshold.21 = INTEGER: 95 degrees Celsius
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureLastShutdown.21 = INTEGER: 0 degrees Celsius
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureState.21 = INTEGER: normal(1)
Richard
Joe Clarke Mon, 12/07/2009 - 11:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This looks okay, but I see no evidence that these SNMP walks line up with the device being shown in DFM.
Start a sniffer trace filtering on SNMP traffic to this same switch seen in the posted DDV screenshot.  Let it run for eight minutes.  Stop the trace, then post the capture file.
richard.tetu Thu, 12/17/2009 - 07:37
Please see after the both snmp trace :
  • from the power supply when she is ok
  • from "       "         "      "       she isn't
An oid has been sending back with ( an 2ND trace)
name: 1.3.6.1.4.1.9.9.13.1.5.1.3.2 (SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.2)
with this value :
Value: INTEGER: 6
What is these value ?
Joe Clarke Thu, 12/17/2009 - 09:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The object in question is ciscoEnvMonSupplyState, and a value of 6 indicates the PS is not functioning.  It may be that DFM doesn't have the latest information about he allowed values of this object, so it displays OTHER instead of a more specific fault condition.
richard.tetu Fri, 12/18/2009 - 00:08
Thanks Joe for the last information .
Should i open a case to the TAC for having at least a view of the DFM code ?
I think that it will be the best for having maybe a patch.
The problematic is that my end user can't launch snmp debug on the equipement as it's an heart of network.
Richard
Joe Clarke Fri, 12/18/2009 - 05:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, a service request should be opened.  The problem does not appear to be with the Cisco code in DFM, but rather with the underlying EMC engine.
Correct Answer
Joe Clarke Fri, 12/18/2009 - 10:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
richard.tetu Mon, 04/19/2010 - 07:51
Hello Dears all, Hello Joe,
I appologize to update this thread so lately.
I have opened an SR and we finally found that is a bug
Subject:
The DFM 3.2 don't report alarm when a 4500 series power supply is switched off.
The state reported is "OTHER"
The value send back is "6" in the CISCO-ENV-MIB in the snmp protocol.
The bug referenced is CSCtg29656 .
It will be available for details  in few days.
Richard
mmimmi2005 Wed, 09/22/2010 - 07:11
Hey Richard
Any news on that? We have the same problem here. All patches and updates installed, but we don't get any Alert in the dfm if a device power supply fails... Happens with 4500 and 6500, it worked once...
regards
Stefan
