update the datasheets
Dec 4th, 2009
I have been searching the cisco website for data on the ISR routers.
Specifically I need the power consumption for the ISR 1941 and the ISR 2951
I was able to find similar info for the ISR 3945 and other ISR models at :
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/data_sheet_c78_553924.html
But this does not include the models I am looking for.
Also, I looking for the "Maximum 3DES Throughput" for the models ISR 1941 and ISR 2951
Again, I was able to find a page which gave this info for other models in the series at :
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps7180/prod_brochure09186a00801f0a72_ns710_Networking_Solutions_Brochure.html
But not the ones I am looking.
Can you tell me this information ?
Or can you send me a link where I might find it ?
Many thanks for your help.
Re
Joe
joe101 Fri, 12/04/2009 - 06:21
Hi Jon,
Thanks for the suggestion.
I have just posted the same question on the link you gave.
Many thanks,
Joe
Jon Marshall Fri, 12/04/2009 - 06:27
Joe
It may be a bug in the new site but you don't seem to have posted it into that thread, you have just posted it twice more into the WAN Routing and Switching forum.
Jon
