update the datasheets
Dec 4th, 2009
I have been searching the cisco website for data on the ISR routers.
Specifically I need the power consumption for the ISR 1941 and the ISR 2951
I was able to find similar info for the ISR 3945 and other ISR models at :
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/data_sheet_c78_553924.html
But this does not include the models I am looking for.
Also, I looking for the "Maximum 3DES Throughput" for the models ISR 1941 and ISR 2951
Again, I was able to find a page which gave this info for other models in the series at :
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps7180/prod_brochure09186a00801f0a72_ns710_Networking_Solutions_Brochure.html
But not the ones I am looking.
Can you tell me this information ?
Or can you send me a link where I might find it ?
Many thanks for your help.
Re
Joe
conmurph Tue, 12/08/2009 - 20:06
  • Cisco Employee,
Hi Joe,
The power specifications for the 1941 and 2951 are in Table 7 of the following documents.
1941
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/data_sheet_c78_556319.html
2951
http://www.cisco.com/en/US/prod/collateral/routers/ps10537/data_sheet_c78_553896.html
In regards to the 3DES throughput, I'm not sure of this value however I assume as these routers are fairly new they haven't released this information at this stage.
Cheers,
Conor
