MPLS TE FA query
Answered Question
Dec 4th, 2009
MPLS TE FA requires bidirectional LSPs but I havent been able to get sufficient reasoning as to why it needs bidir LSPs
(I read that CSPF does some bidir checks before installing it but I need some more insight into this)
Anyone has more detailed knowledge on why FA requires bidir LSPs ?
Correct Answer by IVAN PEPELNJAK about 6 years 9 months ago
You should consider two scenarios:
(A) The tail-end LSR advertises point-to-point adjacency to head-end LSR without having an actual transport path. This is plain stupid and it's not hard to build a scenario resulting in a routing loop.
(B) The head-end LSR adverises point-to-point link to the tail-end LSR in its LSA, the tail-end LSR doesn't advertise the adjacency, but other routers still consider the unidirectional adjacency in their SPF algorithm. In OSPF case, this is a clear violation of step 2.b of algorithm described in Section 16.1 of RFC 2328 (page 163 of the RFC).
There are very good reasons why the bidirectional check is in mandated in the SPF algorithm and even if a vendor X might decide it's time to break the RFC rules (and maybe even call that "innovation") the third-party routers (from vendors still believing in following the RFCs) in a mixed-vendor network would ignore such "adjacencies".
Fixed an obvious stupidity: I write about "LSRs" not "LSPs"
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 12/04/2009 - 10:01
Hello Ulatif,
I made some search on the web and I've found two recent RFCs
http://tools.ietf.org/html/rfc5439
http://tools.ietf.org/html/rfc4206
here FA means Forwarding Adjacencies.
the RFCs describe possible multi-level approaches for MPLS TE scalability something like PE to PE tunnels that are not setup over physical links but over a full mesh of these FA MPLS TE tunnels.
From this hierarchical approach can come this need for bidirectional tunnels that is something new to me too.
Hope to help
Giuseppe
jcozzupoli Fri, 12/04/2009 - 19:31
Hi Usman,
I have never used this feature myself, but reading the configuration guide you quoted, this says not to use "autoroute announce" in the tunnel configs. This would indicate to me that it could be more to do with CEF and the LSP hops in the CEF adjacencies.
This is just a general thought, i'll be reading up on this for sure now!
Joe.
ulatif Sat, 12/05/2009 - 06:57
Thanks Joe
[We need to catchup (my MSN is stuffed these days).]
jcozzupoli Sat, 12/05/2009 - 18:15
Hi Usman,
Yes we do need to catch up mate.
I have done some further reading and would like to explain what I understand to you, for yours and my benefit.
If we consider the following topology:
R1--------R2--------R4-------------R5-------R7
R1--------R3-------------------------R6-------R7
If we build a TE tunnel between R2->R5 and then also between R3->R6 for R1 to get to R7 it doesn't know about the TE tunnels, it only knows and bases its SPF decisions based on the IGP metrics. So, to get the TE tunnel considered in SPF calculations we need to use the FA command under the tunnel configurations and Ra can take advantage of the dual paths (as to why we use TE in the first place). So because of this, the tunnels need to be bidir as from the perspective of R1 and R7, who don't know or care about the TE tunnels and only care about IP Link connectivity, they need to make sure there is a LSP for their packets/labels to travel over to get to their destinations within the other POP/AS.
During this process, IS-IS still runs bidirectional checks. This means that if you have a TE tunnel from R2 to R5 that you've configured with you
also need to have a similarly configured tunnel from R5 to R2 in order for forwarding adjacency to be considered in R1's IGP SPF. If you don't, even after receiving IS-IS LSPs about the tunnel link, R1 will not install it in the routing table because only one of the links is up.
Cheers,
Joe.
ulatif Sun, 12/06/2009 - 01:44
Joe,
Remember (in your example), R2 -> R5 tunnel is one entity and R5 -> R2 tunnel is a separate entity - they dont have any direct interaction.
So why would OSPF/ISIS care about a forward path through a TE LSP and reverse path through an LDP LSP etc ?
If a bidirectional check is performed, but I need to know why?
jcozzupoli Sun, 12/06/2009 - 02:16
Hey Usman,
Well the only reason I can see why is because once the FA is advertised in the IGP its treated as an IP Link and not a TE Tunnel, and therefore you cannot send TE reservation messages across/over it. So because of this, your TE Tunnel will not come up, so there has to be a way for the IGP to see the link as up and that is done by IS-IS bidir checks. OSPF doesn't support FA, only IS-IS
Remember in my example R1 and R7 are P routers and the PE(ASBRs) are R2, R3 and R5, R6. TE was formed between the ASBRs and then advertised to the P routers.
Cheers,
Joe.
ulatif Sun, 12/06/2009 - 02:22
Hi Joe,
Answers/questions inline -
"Well the only reason I can see why is because once the FA is advertised in the IGP its treated as an IP Link and not a TE Tunnel, and therefore you cannot send TE reservation messages across/over it. So because of this, your TE Tunnel will not come up, "
USMAN>> TE tunnel does come up, it always comes up and is treated as TE tunnel i.e. you can reserve bandwidth etc over it.
"so there has to be a way for the IGP to see the link as up and that is done by IS-IS bidir checks. OSPF doesn't support FA, only IS-IS"
USMAN>> OSPF supports FA.
regards
Usman
jcozzupoli Sun, 12/06/2009 - 02:34
Hi Usman,
I know its a TE tunnel and therefore does the reservation messages and so forth. I was more talking about from the perspective of R1 and R7 where TE isn't configured and just see's the route in its routing table/ IGP database.
Yes OSPF does support FA, the Cisco Press book I was reading over needs to be updated as it says only IS-IS and not OSPF.
We should discuss this over the phone.
Cheers,
Joe.
ulatif Sun, 12/06/2009 - 03:18
ISIS or the common OSPF protocol doesnt perform bidirectional checks.
I think this bidirectional check is made by CSPF. But still dont know why :)
jcozzupoli Sun, 12/06/2009 - 14:58
Hi Usman,
Yes it is only for SPF. Like I explained above, SPF only see's the link as an IP Link and not as a TE Tunnel. So, for SPF to advertise the link into the IGP it has to know its path to and from the destination for the link to be up in the SPF database. If you think of basic LSP FECs, you need a FEC to go over the tunnel in 1 direction, and a FEC to come back over the link in the opposite direction. If we only configure a TE Tunnel Uni-directionally, traffic R1 sends to R7 will go over the TE tunnel R2 to R5 but if there is no TE Tunnel from R5 to R2 then SPF will decide on a different path based on the IGP Metrics. By nature, TE LSP's are bidirectional as CSPF requires reservation messages towards the destination, and on its return path. But for TE FA to work in both ways, there needs to be 2 tunnels, 1 in each direction so return traffic will go over the TE Tunnel.
HTH.
Cheers,
Joe.
ulatif Sun, 12/06/2009 - 16:44
Joe,
"Yes it is only for SPF. Like I explained above, SPF only see's the link as an IP Link and not as a TE Tunnel. So, for SPF to advertise the link into the IGP it has to know its path to and from the destination for the link to be up in the SPF database. If you think of basic LSP FECs, you need a FEC to go over the tunnel in 1 direction, and a FEC to come back over the link in the opposite direction. If we only configure a TE Tunnel Uni-directionally, traffic R1 sends to R7 will go over the TE tunnel R2 to R5 but if there is no TE Tunnel from R5 to R2 then SPF will decide on a different path based on the IGP Metrics"
USMAN>> If that was the case, why can't SPF see the return path as a normal link (instead of TE) which would be there already.
USMAN>> By nature, TE LSPs are uni-directional
jcozzupoli Sun, 12/06/2009 - 22:01
Hi Usman,
Let me summarise in one post what I have been trying to say above.
  • CSPF performs a SPF check that will decide the SPF between the MPLS TE endpoints. This SPF may or may not be the SPF based on the IGP. The LSP nail up along the SPF.
  • The CSPF does make sure that the path is bidir, but that is to ensure that the SPF will support an end to end LSP. The LSP must be bidir otherwise it is broken.
  • By nature, not configuration, MPLS-TE's are bi-dir (CSPF with RSVP) but for TE FA, there needs to be 2 FA's and therefore are bi-dir by nature and configuration.
Thus, you could say that CSPF makes sure that the path selected is bidir to ensure that you don't have a broken LSP.  If the SPF is not bidir, the LSP will not work. An LSP underpins an MPLS TE Tunnel. As it's a targeted LDP session, and as such must be bi-directional.
Cheers,
Joe.
Message was edited by: jcozzupoli
Giuseppe Larosa Sun, 12/06/2009 - 23:52
Hello Joe, Usman
from the link provided by Usman
1)the feature overview clearly states:
The MPLS TE Forwarding Adjacency feature allows a network administrator to handle a traffic engineering, label-switched path (LSP) tunnel as a link in an Interior Gateway Protocol (IGP) network based on the Shortest Path First (SPF) algorithm. A forwarding adjacency can be created between routers regardless of their location in the network. The routers can be located multiple hops from each other, as shown in Figure 1.
My understanding is that MPLS TE are unidirectional in the forwarding plane, the fact that RSVP messages used to setup the tunnel need to be exchanged is part of signalling plane and of course requires bidirectional messages but it is a distinct aspect.
As it is reasonable to build an FA a pair of tunnels have to be used with the command to declare the forwarding adjacencies
from the same link:
2) Note:
You must configure a forwarding adjacency on two LSP tunnels bidirectionally, from A to B and B to A. Otherwise, the forwarding adjacency is advertised, but not used in the IGP network.
The objective is to build the equivalent of a direct link between A and B.
Hope to help
Giuseppe
ulatif Tue, 12/15/2009 - 03:46
Guiseppe & Joe,
Yes agree to an extent that FA is probably looking for equivalent of a direct link A->B and B->A before actively installing it but this then creates loopholes with regards to whether the LSP A->B and B->A needs to be exactly identical i.e. Loopback0 on A to Loopback0 on B and vice versa? or can we use Loopback0 on A to Loop0 on B when going from A->B and then Loopback1 on B to Loop0 on A when going from B->A ?
I ask this because in some of my lab simulations that i have done, i can see that the FA still works even if Loopbacks from A->B and B->A are not identical.... so this still leaves open the question as to what exactly the SW is checking for before installing the FA as a link -
This brings me to my next point with regards to FA in scenarios where we used inter-area TE tunnels.
I'll open a new discussion on that one.
IVAN PEPELNJAK Thu, 03/25/2010 - 03:57
The MPLS TE FA is a point-to-point link between two non-adjacent routers (let's call them A and B) established over unidirectional MPLS LSPs (established through RSVP TE extensions). If you want an SPF routing protocol to treat a point-to-point entity as a link, the adjacency must be reported by both sides of the link (A-to-B and B-to-A), otherwise the SPF algorithm rejects the link when building the topology database (this check prevents, among other things, blackholing due to unidirectional links).
Furthermore, A and B have to be able to forward packets across the point-to-point entity, otherwise you could easily end with a routing loop (remember: you can specify metric on MPLS TE tunnel). The exception is the OSPF virtual circuit, which always costs as much as the underlying physical path (thus preventing the routing loops) and where OSPF takes special precautions to prevent black holes.
If you have an MPLS TE LSP from A to B (but not the reverse LSP), then A can send packets directly to B, but not vice versa, so you could get routing loops in reverse direction (plus you'd fail the check in the SPF algorithm). Thus you need two independent MPLS TE LSPs.
Does this make sense?
Ivan
ulatif Thu, 03/25/2010 - 16:49
Hi Ivan,
I agree with what you are saying and understand that TE FA is defined as type p2p in IGP (e.g. OSPF).
But as we know that TE LSPs are unidirectional and independant of each other e.g. if you have and LSP from A -> B and an LSP from B -> A, these are two seperate TE LSPs independant of each other.
We also know that IGP shorcut (autoroute announce in Cisco) doesnt perform this check but then it also doesnt announce the TE LSP as a link in the IGP but only advertises it as a directly connected route in the head-end routers routing table.
Therefore, when we see the restriction that TE FA needs bidirectional LSPs, one would ask the question, what would break if we didnt have bidrectional TE LSPs - you mentioned that it can lead to loops or black holing ?
TE FA is also not supposed to have IGP peering foirmed over it (e.g. as normally on a p2p link, IGP forms neighbor relationship using Hellos etc) - its only there for SPF to treat it as a potential path to destination.
It would be nice if you could highlight a scenario where (using TE FA) and we break the rule that FA doesnt check for bidrectional LSPs and installs the TE FA even for a unidirectional LSP, in what way does it lead to loops or blackholing ? an example would be nice..
P.S. I am great fan of yours btw ... started my MPLS basics from your book and today definitely attribute my CCIE SP to the knowledge gained from reading your materials.
cheers
Usman
Correct Answer
IVAN PEPELNJAK Sat, 03/27/2010 - 02:31
ulatif Sat, 03/27/2010 - 03:56
okay I presume when you said "LSP" in the above reply, you meant "LSR" ?
In regards to your statement :
(A) The tail-end LSP advertises point-to-point adjacency to head-end LSP without having an actual transport path. This is plain stupid and it's not hard to build a scenario resulting in a routing loop.
USMAN>> Why would a tail-end LSR advertise p2p adjacency to head-end LSR if it has no TE FA configured ? This is where we started the discussion that head-end has TE FA configured but tail-end has no TE FA configured so head-end is the only device advertising the adjacency to its IGP peers. Pls clarify what you mean by this point. Maybe I have misunderstood.
(B) The head-end LSP adverises point-to-point link to the tail-end in its LSA, the tail-end doesn't advertise the adjacency, but other routers still consider the unidirectional adjacency in their SPF algorithm. In OSPF case, this is a clear violation of step 2.b of algorithm described in Section 16.1 of RFC 2328 (page 163 of the RFC).
USMAN>> You have a point there - agree 100%
I think a snapshot of the actual process of TE FA advertisment into IGP is probably what I need.
From your description, It seems to me that TE FA would be advertised in IGP as a link between RID of head-end and RID of tail-end (even if head-end and tail-end are physically multiple hops away).
And once TE FA gets advertised into IGP, the head-end advertises the adjacency to other IGP peers but if tailend has no adjacency to the head-end its a violation of RFC 2328 with potential risks.
Is this a correct understanding ?
thanks,
Usman
IVAN PEPELNJAK Sat, 03/27/2010 - 09:10
#1: Sure, it's LSR. Fixed.
#2: If you want to stay within the rules of OSPF or IS-IS RFC and have unidirectional LSP in topology database, the tail-end LSR has to lie. As I said, a bad idea, but the only thing you can do unless you violate OSPF rules. It's so clearly stupid that we can be almost sure it's not used by anyone.
#3: Your understanding is correct. To get a more in-depth view, just take 3 routers, configure MPLS TE tunnel and forwarding adjacency between two of them and perform "show ip ospf database router [ self-originate ]".
ulatif Sat, 03/27/2010 - 16:18
"........the tail-end LSR has to lie. As I said, a bad idea, but the only thing you can do unless you violate OSPF rules. It's so clearly stupid that we can be almost sure it's not used by anyone."
Ivan - you wont believe it but we have a vendor (in the top 3 vendors around the world) who is currently doing that and i caught them in the act....
This is why I initiated the discussion..
Sorry cannot name the vendor on the forum.
ulatif Sun, 03/28/2010 - 00:29
Ivan, just so I have a correct understanding of our discussion, if assume we have a special case of one-hop TE tunnel, dont you think the head-end can install TE FA into IGP because the tail-end even though it doesnt have a TE FA back to head-end still has an OSPF adjacency to the head-end via the physical link ?
ulatif Sun, 03/28/2010 - 01:07
Sorry ... You mean we dont need FA in the opposite direction from tail-end to head-end right ?
Or do you mean we dont need FA at all for one-hop TE ?
because if its the latter, then I have lost you... coz in my understanding, we can still use a higher IGP cost on physical interfaces and have TE FA used for forwarding on one-hop TE.
Anyway, I appreciate your feedback on this issue.
ulatif Sun, 03/28/2010 - 03:40
Ivan - correct me if I am wrong:
I see from the "show ip ospf database router self-originate" that the TE FA gets advertised in the following format into IGP LSDB:
Example:
R2#
    Link connected to: another Router (point-to-point)
     (Link ID) Neighboring Router ID: 10.3.3.3
     (Link Data) Router Interface address: 0.0.0.9
      Number of TOS metrics: 0
       TOS 0 Metrics: 1
And if the tail-end (whether or not its physically one-hop away or multiple hops away) has a TE FA configured in the reverse direction, I see:
R3#
     (Link ID) Neighboring Router ID: 10.2.2.2
       TOS 0 Metrics: 1
Normally, a real physical link in OSPF LSDB appears with "Link Data:" either as a network mask or as a meaningful IP address.
It appears however that for a TE Forwarding adjacency (which is not a real physical link but more like virtual link between two peers), the "Link Data:" contains some form of a common identifier in the format of 0.0.0.xxx where both head-end and tail-end share the same identifier.... and this is probably how IGP ensures that there is a two-way adjacency between the peers...
It'll be interesting to know what rules the peers follow when selecting this common 0.0.0.xx identifier for the mutual FA between each other.
ulatif Sun, 03/28/2010 - 18:01
Thanks for the direction.
So its the MIB-II ifIndex value - this obviously then is a local decision and not mutual.
So I am now clear on the fact that for multi-hop TE FAs, a bidirectional adjacency check is necessary but i am still not quite clear on a one-hop TE coz for a one-hop TE, if head-end has TE FA configured and tail-end has no TE FA confiured, the tail-end still has a p2p adjacency to the head-end via the physical link (assuming physical interfaces are defined as type p2p), so if a vendor is not performing bidirectional TE FA check for one-hop TE, is that still not conforming to 2328 ?
IMO, I think they would/should still be non conforming to 2328 because TE FA is advertised as a seperate adjacency by the head-end (on top of the normal p2p adjacency that exists over physical interfaces) and requires a corresponding seperate reverse adjacency from tail-end to head-end - but then this opens the question of how head-end/tail-end and other IGP peers keep track of which adjacency is relevant to which TE tunnel FA ?? because hypothetically speaking, two routers connected back-to-back can still have many one-hop TE tunnels configured between them (for different purposes etc).
ulatif Tue, 03/30/2010 - 08:21
Ivan - following on from our discussion:
I connected the 3rd party devices to a Cisco router in the following topology:
C3800-------R1----------R2
                  -----R3-----
Router IDs are as follows:
R1 = 192.168.128.101
R2 = 192.168.128.102
R3 = 192.30.102.1
The link IPs are as follows:
R1 <-> R2 = 192.168.168.100/30 (p2p)
R1 <-> R3 = 192.168.168.104/30 (p2p)
R3 <-> R2 = 192.168.168.108/30 (p2p)
I only had one explicit-path based TE tunnel going from R1->R3->R2 so head-end was R1 and tail-end was R2 with FA configured.
There was no reverse TE FA from R2 back to R1.
The C3800 still installed the TE FA half-adjacency into its IGP, see below:
Below is a snapshot of LSDB (self-originated router LSA) from Router-1 (3rd party):
         OSPF Process 1 with Router ID 192.168.128.101
                         Area: 0.0.0.0
                 Link State Database
  Type      : Router
  Ls id     : 192.168.128.101
  Adv rtr   : 192.168.128.101
  Ls age    : 134
  Len       : 120
  Options   :  E
  seq#      : 8000037b
  chksum    : 0x87f9
  Link count: 8
     Link ID: 192.168.128.101
     Data   : 255.255.255.255
     Link Type: StubNet
     Metric : 0
     Link ID: 192.168.128.100
     Data   : 0.0.0.14
     Link Type: P-2-P
     Metric : 10
     Link ID: 192.30.102.1
     Data   : 192.168.168.105
     Link Type: P-2-P
     Metric : 50
     Link ID: 192.168.168.104
     Data   : 255.255.255.252
     Link Type: StubNet
     Metric : 50
     Data   : 192.168.168.101
     Link Type: P-2-P
     Metric : 100
     Link ID: 192.168.168.100
     Link Type: StubNet
     Metric : 100
     Link ID: 192.168.192.2
     Data   : 192.168.168.113
     Link Type: P-2-P
     Metric : 100
     Link ID: 192.168.168.112
     Link Type: StubNet
     Metric : 100
From the C3800, I see the below:
  LS age: 308
  Options: (No TOS-capability, No DC)
  LS Type: Router Links
  Link State ID: 192.168.128.101
  Advertising Router: 192.168.128.101
  LS Seq Number: 8000037B
  Checksum: 0x87F9
  Length: 120
  Number of Links: 8
     (Link ID) Neighboring Router ID: 192.168.128.100
     (Link Data) Router Interface address: 0.0.0.14
       TOS 0 Metrics: 10
And the C3800 even calculates its routing path via this unidirectional TE FA:
CIS375024T.1#show ip route 192.168.128.100
Routing entry for 192.168.128.100/32
  Known via "ospf 1", distance 110, metric 11, type intra area
  Last update from 192.168.168.113 on Vlan33, 00:07:02 ago
  Routing Descriptor Blocks:
  * 192.168.168.113, from 192.168.128.100, 00:07:02 ago, via Vlan33
      Route metric is 11, traffic share count is 1
The outgoing cost on the C3800 towards R1 was set = 1 and the Loopbacks on 3rd party routers have a cost = 0.
So the question now is why did C3800 install this unidirectional FA into its IGP and even ran SPF based on this ??
(I'll attach a full "show ospf database " from the devices in the above topology.)
I can provide any further outputs if necessary but to me it doesnt quite look like even the Cisco devices are checking for a bidirectional adjacency ?? or maybe i am missing something obvious here.
Richard Gallagher Wed, 03/31/2010 - 08:28
Hey Usman,
Long time no see buddy! OK, so had a look at this and here's the what I read and then what I see......
From what I read this is how is should work:
Let's say we have the following topology:
[A] ---- [B] ---- [C]
- Single hop between tunnel end points - One FA tunnel is sufficient (Tunnel AB) – with direct link meets TWCC (two way connectivity check) requirement
- Multiple hops – At least two FA tunnels in opposite direction (Tunnel AC + Tunnel CA). FA is unidirectional so that two FAs, one from head-end router to the tail-end router and vice versa, are required to pass OSPF TWCC and can be used to route traffic.
But I see in reality is not like this, I lab'd this up today and even for one hop tunnel I need bi-dir tunnels for it to be used by IGP, here is the config from one router, it's a one hop tunnel to it's neighbor:
P1#sh run int e1/0
Building configuration...
Current configuration : 104 bytes
interface Ethernet1/0
ip address 192.168.7.1 255.255.255.252
mpls traffic-eng tunnels
mpls ip
end
P1#sh run int tun 1
Current configuration : 223 bytes
interface Tunnel1
ip unnumbered Ethernet1/0
ip ospf cost 2
tunnel mode mpls traffic-eng
tunnel destination 192.168.7.2
tunnel mpls traffic-eng forwarding-adjacency
tunnel mpls traffic-eng path-option 1 dynamic
end
P1#sh mpls traffic-eng forwarding-adjacency 192.168.7.2
  destination 192.168.100.4, area ospf 1  area 0, has 1 tunnels
    Tunnel1     (load balancing metric 0, nexthop 192.168.7.2)
                (flags:  Forward-Adjacency, holdtime 0)
P1#
P1#
P1#sh ip route | inc Tunnel1
P1#
But then when I no shut a tunnel pointing back we get the IGP using it:
O     192.168.6.0/24 [110/12] via 0.0.0.0, 00:00:01, Tunnel1
O     192.168.9.0/24 [110/12] via 0.0.0.0, 00:00:01, Tunnel1
O     192.168.10.0/24 [110/12] via 0.0.0.0, 00:00:01, Tunnel1
O     192.168.12.0/24 [110/12] via 0.0.0.0, 00:00:01, Tunnel1
O        192.168.100.4 [110/3] via 0.0.0.0, 00:00:01, Tunnel1
O        192.168.100.6 [110/13] via 0.0.0.0, 00:00:01, Tunnel1
P1#
And for completeness of course for multi-hop tunnels bi-dir tunnels are required for the FA to be used by the IGP
ulatif Thu, 04/01/2010 - 04:56
Thanks for replying Rich.
For back-to-back connected routers:
[A] ---- [B]
If we have one-hop TE from A -> B, but nothing in the reverse direction, you mentioned that the TWCC is satisfied because of the physical link.
But whats confusing me is that the physical link is a seperate link than the TE FA link so is the TWCC (as per RFC) a requirement per link ? or as long as the tail-end router [B] has any direct path back to the headend [A], it fulfills the RFC 2328 requirement ??
I would have thought every link adjacency needs to have its own corresponding TWCC ?
Also the "Link Data" value that I see for TE FA related p2p link adjacency in the OSPF LSDB seems to have a value 0.0.0.xx where "xx" seems to be common for a TE shared between tunnel end-points - instead of MIB-II value as suggested by RFC-2328 ?
(pls see my previous posts that show this info)
Richard Gallagher Thu, 04/01/2010 - 05:25
I don't see the same behavior as you, l have the same P1--P3 setup, here is the OSPF info:
Router P1:
     (Link ID) Neighboring Router ID: 192.168.100.4
     (Link Data) Router Interface address: 0.0.0.13
      Number of MTID metrics: 0
       TOS 0 Metrics: 2
P1#sh snmp mib ifmib ifindex lo0
Interface = Loopback0, Ifindex = 11
Router 3:
     (Link ID) Neighboring Router ID: 192.168.100.2
     (Link Data) Router Interface address: 0.0.0.12
       TOS 0 Metrics: 2
P3#show snmp mib ifmib ifindex lo0
As you can see the link data is different in each case and not common as you see, but the ifindex is the same for both loopbacks.
IVAN PEPELNJAK Thu, 04/01/2010 - 05:53
The value in the link data field should be the ifindex of the tunnel interface (the point-to-point link between the routers) not the ifindex of a loopback (MPLS TE router-id).
ulatif Thu, 04/01/2010 - 06:05
To clear out confusion around one-hop TE and whether or not a reverse identical adjacency is required or not, I
have found the answer in the RFC 2328 (as Ivan rightly previously pointed me to this):
Section:
16.1.  Calculating the shortest-path tree for an area
Page-162:
2(b):
Otherwise, W is a transit vertex (router or transit
                network).  Look up the vertex W's LSA (router-LSA or
                network-LSA) in Area A's link state database.  If the
                LSA does not exist, or its LS age is equal to MaxAge, or
                it does not have a link back to vertex V, examine the
                next link in V's LSA.[23]
    [23]Note that the presence of any link back to V is sufficient; it
    need not be the matching half of the link under consideration from V
    to W. This is enough to ensure that, before data traffic flows
    between a pair of neighboring routers, their link state databases
    will be synchronized.
So atleast this clears out the confusion.
ulatif Thu, 04/01/2010 - 06:10
And in regards to the "Link Data" contained in the LSA, I still donot see it to be the same as the SNMP MIB IFINDEX, see below:
R3-PE#sh snmp mib ifmib ifindex Tun35
Interface = Tunnel35, Ifindex = 8
R3-PE#sh ip ospf database router self-originate
            OSPF Router with ID (10.3.3.3) (Process ID 100)
                Router Link States (Area 33)
  LS age: 1482
  Options: (No TOS-capability, DC)
  Link State ID: 10.3.3.3
  Advertising Router: 10.3.3.3
  LS Seq Number: 80000005
  Checksum: 0x186E
  Length: 72
  Number of Links: 4
     (Link ID) Neighboring Router ID: 10.5.5.5
     (Link Data) Router Interface address: 0.0.0.10
       TOS 0 Metrics: 10
Unless if MIB-II value is a different value or represented differently ? than the one shown by the "show snmp mib ifindex..." command ??
