NBAR class-map not marking packets
Answered Question
Dec 4th, 2009
I have a WAN QoS policy that includes a nested service-policy, which includes a class-map for marking routing protocol traffic using NBAR. I cannot see any hit's on it. Can anyone tell me what I am doing wrong?
The IOS version is 12.4(22)T3
IP CEF is on
I have put on, and taken off the ip nbar protocol-discovery command, with no effect
class-map match-all RealTime
description class used for VoIP
match access-group name VOIP_acl
class-map match-any BurstyLo
description VoIP Call Signaling & Management
match ip dscp af21
match access-group name VOIPControl_acl
class-map match-any BurstyHi
description Multicast and other [UDP] approved applications
match access-group name IPWAN_MULTICAST_ACL
match access-group name VTC-Codecs_acl
class-map match-any ROUTING-PROTOCOLS
description prepare to separate BGP & EIGRP in BurstyHi
match protocol bgp
match protocol eigrp
policy-map MARK-ROUTING-PROTOCOLS
description Keep dscp markings for BGP & EIGRP
class ROUTING-PROTOCOLS
  set ip dscp cs6
policy-map IPWAN-COS
description add RT priority bw when needed
class RealTime
  set ip dscp ef
    priority 702
class BurstyHi
    bandwidth remaining percent 40
  set ip dscp af31
  service-policy MARK-ROUTING-PROTOCOLS
class BurstyLo
  set ip dscp af21
class class-default
    bandwidth remaining percent 60
     random-detect
  set ip dscp default
service-policy output IPWAN-COS is placed on the Multilink1 interface
sh policy-map int
Multilink1
  Service-policy output: IPWAN-COS
    queue stats for all priority classes:
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 708270/37005226
    Class-map: RealTime (match-all)
      708270 packets, 36966650 bytes
      5 minute offered rate 3000 bps, drop rate 0 bps
      Match: access-group name VOIP_acl
      QoS Set
        dscp ef
          Packets marked 708270
      Priority: 702 kbps, burst bytes 17550, b/w exceed drops: 0
    Class-map: BurstyHi (match-any)
      1071 packets, 66928 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name IPWAN_MULTICAST_ACL
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: access-group name VTC-Codecs_acl
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: access-group name VOIPControl_acl
        5 minute rate 0 bps
      Queueing
      (pkts output/bytes output) 1071/66930
      bandwidth remaining 40% (948 kbps)
      QoS Set
        dscp af31
          Packets marked 1071
      Service-policy : MARK-ROUTING-PROTOCOLS
        Class-map: ROUTING-PROTOCOLS (match-any)
          0 packets, 0 bytes
          Match: protocol bgp
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: protocol eigrp
            0 packets, 0 bytes
            5 minute rate 0 bps
          QoS Set
            dscp cs6
              Packets marked 0
        Class-map: class-default (match-any)
          Match: any
    Class-map: BurstyLo (match-any)
      14 packets, 737 bytes
      Match: ip dscp af21 (18)
        0 packets, 0 bytes
        5 minute rate 0 bps
        5 minute rate 0 bps
      QoS Set
        dscp af21
          Packets marked 14
      3489665 packets, 1200723572 bytes
      5 minute offered rate 387000 bps, drop rate 0 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops) 0/1593/0
      (pkts output/bytes output) 3532671/1264911756
      bandwidth remaining 60% (1422 kbps)
        Exp-weight-constant: 9 (1/512)
        Mean queue depth: 0 packets
        class     Transmitted       Random drop      Tail drop          Minimum        Maximum     Mark
                  pkts/bytes     pkts/bytes       pkts/bytes          thresh         thresh     prob
        0         3536339/1265646110   1593/1609605        0/0                 20            40  1/10
        1               0/0               0/0              0/0                 22            40  1/10
        2              18/944             0/0              0/0                 24            40  1/10
        3               0/0               0/0              0/0                 26            40  1/10
        4               0/0               0/0              0/0                 28            40  1/10
        5               0/0               0/0              0/0                 30            40  1/10
        6               0/0               0/0              0/0                 32            40  1/10
        7               0/0               0/0              0/0                 34            40  1/10
      QoS Set
        dscp default
          Packets marked 3489665
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
routing protocols like BGP and EIGRP have already their packets marked with CS6 = ip precedence 6 you can verify this with a packet capture.
what can be important on some platforms that miss the hidden system queue is to provide BW resources for routing protocols.
if you are using an ISR or other sw based routers they have an hidden system queue for routing protocols messages so your "user" classes cannot match these packets. The hidden queue is the reason behind the default settings of max-reserved-bandwidth 75% that allows to allocate 75% of BW (as per bandwidth command administrative parameter) to user traffic leaving 25% for the system queue.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 12/04/2009 - 11:45
  • Hall of Fame,
    Founding Member
Hope to help
Giuseppe
Edison Ortiz Fri, 12/04/2009 - 18:36
  • Hall of Fame,
    Founding Member
Hope to help
Giuseppe
Caveat, this behavior has changed with 20T and later
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m1.html#wp1039174
