Link down state
Answered Question
Dec 4th, 2009
Dear friends,
I came to know that ports in up / down state and if managed will be notified according to the notification subscription.
What about ports in down/down state? Dont they indicate a failure condition?
When a server NIC gets back or if the cable has got loose, the port should go to a down/down state which indicates a failure condition
which should be notified as well.
Thanks and Regards
Gautam
Correct Answer by Joe Clarke about 7 years 3 months ago
The down/down state has two meanings.  In SNMP speak, down/down means the port is administratively shutdown and thus is also operationally down.  In IOS CLI speak, down/down refers to both the line and the protocol being down (i.e. layers 1 and 2 are down).
If you are asking about DFM, DFM will see a port which has a CLI status of down/down but an SNMP status of up/down as being down, and will generate an event.  If, however, you have down a "shutdown" on the port/interface, then it will be down/down from the SNMP point of view, and thus not generate an event in DFM.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 12/04/2009 - 14:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
