Does CME 8.0 have a compatible version of CUE for a 2851 with an ISE?
Dec 4th, 2009
I have a 2851 that I need to upgrade and I'm looking at putting CME 8.0 on it, but have not been able to find a document that
states whether there is a compatible version of CUE that can be installed on the Integrated Service Engine. Has anyone been able to try this, or have a link to a document that states compatibility?
Brandon Svec Tue, 12/08/2009 - 19:44
  • Silver, 250 points or more
  • Community Spotlight Award,
    Small Business, February 2016
I am not aware of needing any special version of CUE.  I have 8.0 on a 2851 running with CUE 7.0.  7.1 should be fine too.
My problem with CME 8 is that the admin GUI is broken and I think I am not alone: https://supportforums.cisco.com/thread/303217
It doesn't really have any new features either so you might just want to stay with something more stable..
Here is CME new features:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
end2endtechs Wed, 12/09/2009 - 10:54
Thanks for the reply, this helps alot. I think I should just stay on version 7.0 for now.
