12-04-2009 10:11 AM - edited 03-19-2019 12:06 AM
Hi ;
try to add the device C7962 and C7915 in CUCM 6.0.1. Manage upgrade the software from CUCM OS. But when i add the new phone from Device > Phone still don't have option C7862 to select. Here the software which loaded in CUCM;
Product Version 6.0.1.3000-7
cmterm-7915.1-0-3.cop
cmterm-7942_7962-sccp.8-5-2.cop
anybody do experices this pls share with me on how to add C7962 & C7915 in CUCM 6.0.1. Many thanks.
rgds
tan
12-04-2009 11:11 AM
Install the latest DevPack for your version, adding the firmware for a phone DOES NOT add support for a phone.
It just add the FW to the TFTP, but it does not modify the DB, which is what DevPacks are for
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-05-2009 07:42 PM
Hi Javalenc ;
did follow your intrsuction download the device package for 6.0 - cmterm-devicepack6.0.1.3121-1.cop.sgn. And i did manage upgraded in my CUCM 6.0. This time i can see the device of C7962 in Device > Device Setting > Device Default, but i don't see the C7915, how to enable C7915 in CUCM ?
Here the sosftware package which is in CUCM 6.0.
Here the device package shown supported C7915.
http://www.cisco.com/web/software/282074299/26751/cmterm-devicepack-6_0_1_3121-1_readme.html
Pls advice, hope can hear you soon. Thanks.
rgds
tan
12-06-2009 07:17 PM
Table 4. Cisco Unified IP Phone Expansion Module 7915 Software Requirements
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/data_sheet_c78-468672.html
You can find the info very easily if you take a couple of minutes to search CCO, i searched 7915 and this was the 2nd hit.
java
if this helps, please rate
12-07-2009 07:00 PM
Javalenc ;
from your table given, CUCM 6.0.1 is not in the support list. Is this mean that in order to support C7915, require upgrade CUCM to 6.1(1) ? Pls confirm. Thanks.
rgds
tan
12-07-2009 07:00 PM
Javalenc ;
rgds
tan
12-08-2009 08:14 AM
Tan,
That is correct. 7915 is not supported on CUCM 6.0.1 and you will need to upgrade to a compatible version. Here is more information:
The Cisco Unified IP Phone 7915 Expansion Module supports the following Cisco Unified IP Phones that run SCCP and SIP: 7962G, 7965G, and 7975G. Phones that run SCCP must run Cisco Firmware Release 8.3(5) or a later release. Phones that run SIP must run Cisco Firmware Release 8.4(1) or a later release.
Table 46 provides Cisco Unified IP Phone 7915 Expansion Module compatibility information for Cisco Unified Communications Manager Release 4.x through Release 7.x.
Find additional information at this URL:
http://www.cisco.com/en/US/products/hw/phones/ps379/tsd_products_support_series_home.html
Firmware Version | Cisco Unified Communications Manager Version |
1.0(2) - SCCP | 4.2(3)SR31 , 4.3(1)2 , 4.3(2)3 , 5.1(1), 5.1(2), 5.1(3b), 5.1(3c), 6.1(1b), 6.1(2), 6.1(3a), 7.0(1) |
1.0(2) - SIP | 7.0(1) |
1.0(3) - SCCP | 6.1(3a), 6.1(4), 7.0(2), 7.1 |
1.0(3) - SIP | 6.1(3a), 6.1(4), 7.0(2), 7.1 |
1 Supports Cisco Unified Communications Manager Release 4.2(3)SR3a or later.
2 Supports Cisco Unified Communications Manager Release 4.3(1)ES22.
3 Supports Cisco Unified Communications Manager Release 4.3(2)SR1a and Release 4.3(2)ES4.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp53059
HTH,
pablogon
