ASA Endpoint Assessment intial deploy issues
Dec 4th, 2009
Anyone else encounter the following problems and have solutions?
- On intial install (Secure desktop never used or cached), download / install takes longer than 3min dispite its small size and being on a local high speed connection. This can be a bit long for a user that just wants to view a webpage.... After it has been installed / cached it only takes seconds.
- On intial install (Secure desktop never used or cached),keyloger prompt, pops UNDER the IE window so that the user does not notice and then times out.
- Virtualization check does not seem to detect that it is running in a VM under Vmware worksation 7, is this like the AV assesment? Can it only detect known products, not general virtualization?
