UCCX 7.0(1)SR04_Build443 login web page from server
Dec 4th, 2009
When I try to login into the web page http://contactserverIP/appadmin  I get an Unauthorized message failed to authenticate. When I login into the same web page from my desktop it works just fine. Any reason on why I can't log into the page from the server?
Rajiv Lal Sat, 12/05/2009 - 04:26
  • Cisco Employee,
It sounds bit strange, please confirm if you are putting the correct credentials?
Also when the login fails please check the Securiy logs in event viewer and app logs and let us know the error that you are getting.
Rajiv
