Anyconnect VPN client 2.3
Answered Question
Dec 4th, 2009
When I run the application, how come I don't see the other drop menus as documented?
Did I install it wrong ?  I don't see options for:
Group
Username
Password
Am I suppose to Not see these yet ?
Correct Answer by JORGE RODRIGUEZ about 7 years 1 month ago
Hi, you are not to see those yet until you connect to the vpn server , so you will upon of launching anyconnect cleint see  a "Connect to: " field to enter VPN server IP address , once that connection is stablished the other drop down fields will display such as what you are asking for.
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Fri, 12/04/2009 - 14:25
Related Content
