SA540 Firewall Allow rules still in place after rule is deleted.
Dec 4th, 2009
SA 540 Firmware 1.0.39
In trying to find a way to make my Optional port DMZ work (separate issue, slow to non existing internet access from DMZ) I created a rule allowing all traffic from the DMZ to the LAN:
I only had these 3 firewall rules:
DMZ to WAN allow all.
LAN to DMZ allow all.
and
DMZ to LAN allow all
After deleting the DMZ to LAN allow all Rule, I still can access the LAN from the DMZ port. Is there a way to see which rules that are REALLY in place?
biraja Tue, 05/04/2010 - 12:33
Hello Sir,
I've come across this query just now and though would answer your concern.
I've checked this with latest 1.1.42 firmware release and the DMZ->LAN firewall rule works as expected.
It his rule is deleted or disabled, I could not pint from DMZ to LAN hosts.
By default, the traffic is blocked from DMZ to LAN.
Once again I apologize for the late response.
Thanks and Regards,
Biraja
