Limiting Bandwidth
Dec 4th, 2009
Hi Dears,
I am Saravanan, working as a network engineer. In one of my customer have 4Mbps Internet, They have 4 vlan groups. Now current setup is Sharing the 4 mbps Internet to every body, but they want to limit the bandwidth in vlan groupwise.
Consider Vlan 1 in 192.168.10.0 /24
Vlan 2 in 192.168.15.0/24
Vlan 3 in 192.168.20.0/24
Vlan 4 in 192.168.21.0/25.
I want to give more bandwidth in vlan 4, around 2mbps, remaining 2mbps should share to all.
I have cisco 4503 as L3 switch and i have MPLs connection to connect to another location.
This limitation of bandwidth should occur only in using of Internet not for LAN or Intranet.
202.X.X.233      202.X.X.234        192.168.10.2    10.4                                   192.168.10.1
ISP link  -------------> Firewall (Checkpoint)  ----------> Proxy server    ----------->   Cisco 4503 -------> distribute in to 4 vlan.
please give a valuable reply.
Thanks for  you spend your valuable time.
Ganesh Hariharan Fri, 12/04/2009 - 22:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi Saravanan,
Bandwidth limitation can be usig qos,Check out the below link for configuring qos as per you requirement.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_12c_ea1/configuration/guide/swqos.html#wp1032145
Hope this will help you to some extent !!
Ganesh.H
psaravanan Sat, 12/05/2009 - 10:23
Very very thanks mr. Ganesh.
Any other related document is there regarding the issue.
