Export tool in CW not work
Answered Question
Dec 5th, 2009
Hi Experts,
     I have LMS 3.0.1 working on windows 2003. when I tried to export any report to csv or pdf, I got it's not worked. a blank window appeared  and disappered repidly. Do you have any idea how could I fix this issue?
Thanks in Advance
Best Regards,
Tri(7)ple
Correct Answer by aieremias about 7 years 7 months ago
I had this problem too and found this in Common Services User Guide:
In Microsoft Internet Explorer 6.0 SP2 and Microsoft Internet Explorer 7.0 browsers, sometimes
problem occurs while exporting the reports in CiscoWorks applications to a PDF or CSV format. This
problem occurs on a Windows XP client machine.
This may be caused by the default security settings in the browsers.
To enable exporting reports in CSV and PDF format in Internet Explorer browsers:
Click Tools > Internet Options.
The Internet Options dialog box opens.
Click the Security tab.
Click Custom level... from the Security level for this zone panel.
The Security Settings dialog box opens.
Select the Enable option for the File Download field.
Click OK.
BR,
Alex
Overall Rating: 5 (1 ratings)
Correct Answer
aieremias Sat, 12/05/2009 - 08:45
Click OK.
BR,
Alex
wael_ashraf Sat, 12/05/2009 - 23:23
Hi Alex,
     thanks for your help. it's helpful. but the issue in my system was in enabling "Automatic prompting  for file downloads" not file down. and it's working now properly.
BR,
777
