Ping through ASA
Answered Question
Dec 5th, 2009
i have a problem as i permitted PING by the following commands:
icmp permit any echo admin-outside
icmp permit any echo-reply admin-outside
icmp permit any echo admin-inside
icmp permit any echo-reply admin-inside
i can ping from outside (PC) to the inside (PC) but i can't ping from the inside(PC) to the outside(PC)
and another question can the interfaces of the firewall ping each outher if i used Extended ping on the firewall -- because in this status both interfaces are not pingging each other too ??
Thanks In Advance
Ayman Yehia
Correct Answer by Conor Cunningham about 7 years 1 month ago
Hi Yehia,
I believe you need to add ICMP to your inspection policy-map.After I issued 'inspect icmp' from within my policy-map it worked.
On my ASA 5505 in my home lab I have the following;
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
Hope that helps.
Conor
Correct Answer by Jon Marshall about 7 years 1 month ago
Thanks In Advance
Ayman Yehia
Ayman
The "icmp permit ..." command controls who interfaces on the firewall can be pinged not which devices can ping through the firewall.
Have a look at this document which covers how to allow ping through an ASA/Pix firewall -
ASA ping
Can the interfaces ping each other - no they can't.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Sat, 12/05/2009 - 15:57
Thanks In Advance
Ayman Yehia
Ayman
ASA ping
Jon
Correct Answer
Conor Cunningham Sun, 12/06/2009 - 11:56
Hi Yehia,
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
Hope that helps.
Conor
