CAM with 4.7 and module with 4.6.1 compatibility
Dec 6th, 2009
I have to upgrade the cam to 4.7 from 4.6.1 due to AV version. However 4.7 is not for modules. Is it possible that i keep the modules as 4.6.1 where i oly upgrade the cam to 4.7. I have a scenario where 3 branches have nac appliances in ha and 6 branches with module. the AV is trend micro 10.x which is not supported with 4.6.1 so i need to upgrade. in branches where there are nac modules i will retain the av to trend micro  8.x and nac version 4.6.1. and the branches where there are nac appliances i will upgrade to 4.7 and av trend micro 10. The cam will also be upgraded to 4.7. Will that work
Overall Rating: 5 (1 ratings)
Faisal Sehbai Mon, 12/07/2009 - 18:41
CAS and CAMs have to be on the same versions, and different versions aren't supported.
It might work, but again, it might not!
