12-06-2009 10:00 AM - edited 03-21-2019 01:52 AM
If OOB configuration through CLI, is not supported for the new UC500 models. Does this mean that there is no support for FAX integration with CUE?
What are the options or Sample configuration guides to receiving Faxes without Fax Machines?
Best regards.
12-06-2009 08:06 PM
T.37 support in CCA is about to be committed, so sometime next year we will have it implemented.
Marcos
12-06-2009 11:09 PM
Will this also mean fax support for the UC520 ?
12-07-2009 12:41 AM
Marcos,
Do you mean that now, Fax T.37 or T.38 can't be configured for UC540 or UC560?
Alejandro
12-07-2009 12:04 PM
It can be configured, it just will not be supported until the configuration exists in CCA. Then, the CCA config will be supported.
12-08-2009 05:56 AM
What Stevens says is correct for T.37. T.38 is enabled by default on the system.
Marcos
12-08-2009 06:27 AM
I know it is available through cli as a IOS feature, but as for UC540 & UC560 OOB configuration is not supported, then I assume this is not supported by Cisco. Correct?
12-08-2009 08:54 AM
That is correct, for the UC540 and for the UC560, it isn't supported yet.
