jumbo frame
Lets talk MPLS,okay so how to let the switch deal with jumbo frame specially when u adjust the mtu size under the interface to 1512..
What is the command to do that?
v  Is it in global configuration [system mtu 1512]?
v  So what's happened to ospf tough?do I need to config under the interface the command: [ip ospf mtu-ignore]
David Williams Sun, 12/06/2009 - 16:21
Good day Alsayed,
The answer to your question is dependent upon what kind of hardware you are changing the MTU on.  Some switches allow interface level modification, while others require a system wide change, which often requires a reboot to take effect.  The link below has information about jumbo and giant frame support on different switching hardware.  I hope that helps.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
Dave
