SA 540 SSL Port forwarding problem on Mac computers
Dec 6th, 2009
We have quite a few MacBook Pro users, and we are trying to set up the SSL VPN for them to access our CRM server and Intranet on the Secure LAN.
When they click the "SSL VPN Port Forwarding Client Installer/Launcher" Icon under VPN -> Port Forwarding they get the following message:
"Port Forwarding requires Internet Explorer 5.0 or higher."
We have tried both Safari and Firefox browsers. Any ideas? Or does Cisco not support any other remote users than Windows IE users?
(SA540 firmware 1.0.39)
Steven Smith Mon, 12/07/2009 - 15:58
Can you verify this same problem occurs if you don't use the port forwarding VPN?  I believe full tunnel works on the SSL VPN's with Mac users.  I will look into this issue.
