aborted calls at run external script step
Dec 6th, 2009
hello everyone
when I was monitoring a script, I noticed a large percentage of calls are aborted on the node " run external script", and a few number of calls listed as " in process". only a small percentage of calls passed this node.
I would like to ask what does this "abort" means, does it mean the the call fails at this node, or the caller purposely terminate the call at this node.
thanks in advance
david.macias Mon, 12/07/2009 - 09:05
  • Blue, 1500 points or more
Yes, more than likely the call is failing at some point in your RES node.  Are you using CVP?  What do the CVP and PG logs tell you?  What does the RES do?
david
applegreen Mon, 12/07/2009 - 12:48
Hi, David
thanks for replying me back
we are using IPIVR instead of CVP and system was under a really heavn load.
one RES was just simplely playing a prompt
Unfortunately some how, I couldn't get the log from IPIVR.
david.macias Mon, 12/07/2009 - 14:20
It is going to be a bit tough to troubleshoot without MIVR logs, any word from the PIM logs?
david
