FWSM anti-dos option?
Dec 6th, 2009
Hi..
I have read that the fwsm has a serveral anti-dos option.
I has seached the fwsm anti-dos related document in CCO, But I can't yet.
first of all, I would like know that,
a. anti-dos feature in FWSM
b. if anti-dos in FWSM, How can I configuration?, Configuration guide
If you help me find it, I would appreciate it.
Thank you.
Jon Marshall Tue, 12/08/2009 - 05:18
syjeon wrote:
Hi..
Thank you.
Have a look at this chapter in the configuration guide -
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/protct_f.html
Jon
Panos Kampanakis Tue, 12/08/2009 - 11:07
One example if you have a static for a server x would be that you want to have 100 conns maximum and 50 embryonics
static (mgmt,test) y x 100 50
The FWSM will proxy to verify that there is no SYN flood and that no more than 100 conns will go using that static.
Another to see a maximum number of connection for a specific traffic class is
policy-map test
class test
  set connection conn-max 100
I hope it helps.
PK
