Cisco 7940 - SPA9000 - SPA400
Dec 6th, 2009
Customer is having issues connecting their Cisco 7940 Phones to their SPA9000/400.  The Cisco 7940 is currently running SIP, yet the device will not show up in the SPA9000 wizard. These phones were provisioned by their old ITSP, according to the provider however, they can delete the original configuration on the phones and connect them with the SPA9000/400. Tested in the lab and were unable to come to a successful conclusion.
David Harper Sun, 12/06/2009 - 21:37
The 7900 phones and the SPA9000 voice system are part of two separate voice solutions.  As such, the 7900 phones will not participate in the auto-discovery and auto-configuration process use by the SPA9000 solution.  Similarly, the SPA9000 wizard does not support the 7900 series phones.  It may be technically possible to get the 7900s to register with the SPA9000 and make and receive calls, but it would require a lot of manual configuration work to set up, and you would not get the full functionality that you get if you use the SPA900 or SPA500 series of phones with the SPA9000.  I'd recommend replacing the 7940 phones with SPA500 series phones in this case.
