MPLS L2 VPN query
Answered Question
Dec 6th, 2009
Hi ,
we have MPLS network running Layer3 VPN.
Presently in legacy network we have trunk between CS1 & Cs2 over transmission (ethernet link), Network diagram is attached herewith
We like to migrate the trunk over MPLS backbone. Can I connect the CS1 & CS2 to respective PE1 & PE2,  after that the L2 VPN can carry the vlan traffic between CS1 & CS2 over L2 VPN.
Looking for the suggestion.
Reagrds,
Nilesh
Correct Answer by Giuseppe Larosa about 7 years 5 months ago
Hello Nilesh,
what you would like to do is indeed possible: what you need is port based EoMPLS and this is supported in most PE nodes.
see
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_any_transport_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1047178
all you need is to use loopback IP addresses that are advertised over the MPLS cloud as LDP endpoints.
1. enable
2. configure terminal
3. interface gigabitethernetslot/interface
4. xconnect peer-router-id vcid encapsulation mpls
where peer-router-id is the other L2 PE loopback ip address.
Be aware that the L2 PE will not discriminate between vlan-ids so if there are vlan-ids that you don't want to propagate you need to use
switchport trunk allowed vlan on the L2 CE node.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 12/07/2009 - 00:01
  • Hall of Fame,
    Founding Member
Hello Nilesh,
see
1. enable
Hope to help
Giuseppe
nilesh_sawant Wed, 12/09/2009 - 05:10
Hi Giuseppe,
Thank you very much for your advice.
Nilesh
