customizing ccmuser webpages
Dec 6th, 2009
is it possible to customize webpages in ucm (ccumser) ? i want to implement our corporate design...
Overall Rating: 5 (1 ratings)
Simon Machielse Mon, 12/07/2009 - 05:32
on cm 4 and lower you would be able to do this but is not supported by cisco and you would need to check or setup the files again after each upgrade.
from cm 5 and higher it is a closed OS and you are not able to upload any customized files or change anything anymore, except ringtones and backgrounds for ip phones etc.
