12-07-2009 12:10 AM - edited 03-15-2019 08:41 PM
I am looking for a document comparing two major versions and a guidelines (pros and cons) as to why a customer who has 4.x would upgrade to 7 instead of 6 or vice versa
thanks
12-07-2009 07:12 AM
That doc doesn't exist, you can look the RNs for each version to see what new features have been included in each
If you search CCO with just the product name you run across docs like this one:
Which contains:
Table 1. New Features in Cisco Unified Communications Manager 7.0
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-07-2009 07:38 AM
Hi Anacleto,
Maybe this doc that I did up not too long ago may help (attached)
Cheers!
Rob
EDIT: The new site won't allow this content for some reason, If you
want the doc just email me @
12-08-2009 12:28 AM
Thanks Rob. I sent you emails about the doc so if you can kindly reply to it
regards
12-08-2009 05:34 AM
Hi Jhun,
It's on the way my friend
Cheers!
Rob
