service-policy on Vlan interface failed
Dec 7th, 2009
  • Silver, 250 points or more
Hi, All!
This is my configuration:
class-map match-any voip_control_trust-CMAP
match ip dscp cs3
match ip dscp af31
class-map match-any voip_rtp_trust-CMAP
match ip dscp ef
class-map match-any internetwork-cntrl-CMAP
match ip dscp cs6
policy-map output_qos-PMAP
class voip_rtp_trust-CMAP
  priority 56
class voip_control_trust-CMAP
  bandwidth percent 2
class internetwork-cntrl-CMAP
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
cisco(config)#int Vlan 2
cisco(config-if)#service-policy output output_qos-PMAP
Configuration failed!
It was tested on 877, 871, 871W, 877W with ios c870-advipservicesk9-mz.124-15.T5.bin, c870-advipservicesk9-mz.124-15.T8.bin, c870-advipservicesk9-mz.124-15.T10.bin, c870-advipservicesk9-mz.124-15.T11.bin, c870-advipservicesk9-mz.124-24.T2.bin
Strange error. Does anybody know what's the problem?
Overall Rating: 4 (3 ratings)
Eugene Khabarov Sat, 12/19/2009 - 09:34
Ok, i tried to make workaround solution:
policy-map OUTPUT_QOS_PMAP
class VOIP_RTP_TRUST_CMAP
    priority 56
class VOIP_CTRL_TRUST_CMAP
    bandwidth percent 2
class INETWORK-CTRL-CMAP
    bandwidth percent 5
class class-default
    fair-queue
     random-detect
  service-policy OUTPUT_QOS_PMAP
service-policy output OUTPUT_QOS_PMAP
interface Vlan2
description *** WAN SVI ***
bandwidth 256
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
bridge-group 1
end
interface BVI1
description *** WAN BVI ***
bandwidth 256
ip address 10.96.0.57 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
end
sh policy-map interface
BVI1
  Service-policy output: OUTPUT_QOS_PMAP
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: VOIP_RTP_TRUST_CMAP (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: 56 kbps, burst bytes 1500, b/w exceed drops: 0
    Class-map: VOIP_CTRL_TRUST_CMAP (match-any)
      0 packets, 0 bytes
      Match: ip dscp cs3 (24)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: ip dscp af31 (26)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      bandwidth 2% (5 kbps)
    Class-map: INETWORK-CTRL-CMAP (match-any)
      6 packets, 896 bytes
      Match: ip dscp cs6 (48)
        5 minute rate 0 bps
      Match: access-group name IKE
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (queue depth/total drops/no-buffer drops) 5/0/0
      (pkts output/bytes output) 6/1120
      bandwidth 5% (12 kbps)
    Class-map: class-default (match-any)
      11 packets, 660 bytes
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 10/0/0/0
      (pkts output/bytes output) 11/660
      Fair-queue: per-flow queue limit 16
        Exp-weight-constant: 9 (1/512)
        Mean queue depth: 0 packets
        class     Transmitted       Random drop      Tail/Flow drop Minimum Maximum Mark
                  pkts/bytes    pkts/bytes       pkts/bytes    thresh  thresh  prob
        0              11/660             0/0              0/0                 20            40  1/10
        1               0/0               0/0              0/0                 22            40  1/10
        2               0/0               0/0              0/0                 24            40  1/10
        3               0/0               0/0              0/0                 26            40  1/10
        4               0/0               0/0              0/0                 28            40  1/10
        5               0/0               0/0              0/0                 30            40  1/10
        6               0/0               0/0              0/0                 32            40  1/10
        7               0/0               0/0              0/0                 34            40  1/10
BUT! Until service-policy is on interface works nothing.
sh int bvi1
BVI1 is up, line protocol is up
  Hardware is BVI, address is 0025.454a.940d (bia 0024.c495.6780)
  Description: *** WAN BVI ***
  Internet address is 10.96.0.57/24
  MTU 1500 bytes, BW 256 Kbit/sec, DLY 5000 usec,
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 74
  Queueing strategy: Class-based queueing
  Output queue: 33/1000/0 (size/max total/drops)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     114 packets output, 11034 bytes, 0 underruns
     0 unknown protocol drops
ping 10.96.0.1 source bvi1
Sending 5, 100-byte ICMP Echos to 10.96.0.1, timeout is 2 seconds:
Packet sent with a source address of 10.96.0.57
Success rate is 0 percent (0/5)
lamav Sat, 12/19/2009 - 13:41
  • Blue, 1500 points or more
Hi:
You cannot apply a policy map on an SVI in the input or output direction.
Also, SVIs do not support CBWFQ, LLQ, WRED or hierarchical MQC QoS, which is what you have configured. The default queing mechanism for an SVI interface is FIFO, in which case there is only one queue anyway and no classifaction or scheduling.
It is true that Cisco allows you to change the queing mechanism on an SVI to WFQ, but in that case there is no manual classifaction and marking of packets. In other words, no MQC QoS configuration.
WFQ is flow-based, so the IOS will automatically (dynamically) create a queue that it will service for each flow that exists. A flow is defined by the source and destination IP addresses, and source and destination TCP/UDP ports. The queues get prioritized service by the scheduler based on a  sequence number (SN) or so-called Finish Time that it assigns to each packet. The lower the number calculated, the greater the packet's priority.
Victor
Eugene Khabarov Sat, 12/19/2009 - 13:55
So what about second approach? Can I apply service-policy to BVI? Why is thi not working?
lamav Sat, 12/19/2009 - 15:57
You gave me a "2" and expect me to continue answering your questions...fuggetaboutit! :-)
Eugene Khabarov Sun, 12/20/2009 - 12:42
Ouch, it's not a school assessment
I'll give you 5 points and correct answer mark if you can help me, i promise
lamav Sun, 12/20/2009 - 14:20
I was just teasing you...thats why I put the smiley face at the end.
I really dont khave an answer regarding BVI interfaces and what youre trying to achieve with them. Otherwise, I would have given you an answer.
Victor
