Remove Health Care (keepalives) CSS 11503
Answered Question
Dec 7th, 2009
We normally distribute the load between two servers by checking if the server its active (using TCP 80), yesterday, we want to remove the Health Care (keepalives) due to a maintenance test, to sent the traffic direct to the server, but the service stop working.
We think we didn’t remove the health care properly, could anybody please help me to know hoe to remove it?
We are using CSS 11503, I’m adding the config.
Correct Answer by Gilles Dufour about 7 years 1 month ago
CSS11503-2(config)# service Linux2
CSS11503-2(config-service[Linux2])# ip add 192.168.20.41
CSS11503-2(config-service[Linux2])# active
CSS11503-2(config-service[Linux2])# show service Linux2
Name: Linux2            Index: 33
  Type: Local            State: Alive
  Rule ( 192.168.20.41  ANY  ANY )
  Session Redundancy: Disabled
  Redirect Domain:
  Redirect String:
  Keepalive: (ICMP   5   3   5 )
  Keepalive Encryption:      Disabled
  Last Clearing of Stats Counters: 08/12/2009 05:29:24
  Mtu:                       1500        State Transitions:            0
  Total Local Connections:   0           Total Backup Connections:     0
  Current Local Connections: 0           Current Backup Connections:   0
  Total Connections:         0           Max Connections:              65534
  Total Reused Conns:        0
  Weight:                    1           Load:                         2
  Weight Reporting:          None
CSS11503-2(config-service[Linux2])# keepalive type none
  Redirect Domain:
  Redirect String:
  Keepalive: (NONE   5   3   5 )
  Mtu:                       1500        State Transitions:            1
  Weight:                    1           Load:                         2
Same if the service is down before disabling the keepalive.
CSS11503-2(config-service[Linux2])# keepalive type icmp
  Type: Local            State: Down
  Redirect Domain:
  Redirect String:
  Last Clearing of Stats Counters: 08/12/2009 05:31:42
  Mtu:                       1500        State Transitions:            4
  Weight:                    1           Load:                         255
  Redirect Domain:
  Redirect String:
  Last Clearing of Stats Counters: 08/12/2009 05:36:08
  Mtu:                       1500        State Transitions:            5
  Weight:                    1           Load:                         2
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Mon, 12/07/2009 - 04:53
you simply need to type "keepalive type none" under the service definition.
CSS11503-2(config)# service test
CSS11503-2(config-service[test])# keepalive type none
Gilles.
rparrat666 Mon, 12/07/2009 - 17:26
H, thank for the answer, at the beginning I thought that was the way, but alter the change, the service was down, is it normal? I was expecting to see the service up but the data going thru without checking the state.
Correct Answer
Gilles Dufour Tue, 12/08/2009 - 02:04
  Redirect Domain:
  Redirect String:
  Weight:                    1           Load:                         2
  Redirect Domain:
  Redirect String:
  Weight:                    1           Load:                         2
  Redirect Domain:
  Redirect String:
  Weight:                    1           Load:                         255
  Redirect Domain:
  Redirect String:
  Weight:                    1           Load:                         2
Gilles.
Related Content
