Termination_Call_Detail closed and invalid numbers
Dec 7th, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
on what integer combination i can see that an ANI is a invalid or closed number? On the Dialer_Detail this is a 7 and 27 as callresult
But what numbers do i need for the same data based on Termination_Call_Detail?
my best guess are the above numbers, but i'm not see if there are correct and if that covers all the data
Thanks in advanced
Edward Umansky Wed, 12/09/2009 - 18:09
Termination_Call_Detail values are detailed in Appendix D of the latest outbound user guide. The TCD records are not as detailed when it comes to dialer results as the Dialer_Detail table, so you may not be able to get the information you need from the TCD alone.
