12-07-2009 02:58 AM - edited 07-03-2021 06:19 PM
Dear all,
I'm experiencing an issue with wireless guest, when accessing a site with https, the traffic is not intercepted by my controller, http sites are intercepted without any issue, I've found a document where this issue is mentioned as bug ID CSCar04580
http://cisco.biz/application/pdf/paws/108501/webauth-tshoot.pdf
could you please let me know what the fix is?
12-07-2009 06:22 AM
This is the correct behavior by default. The controller looks for the HTTP Get request to redirect to the webauth login page so its only watching for port 80. When they are trying to hit a HTTPS webpage the request is on port 443 so by default the controller doesn't redirect to the webauth page. You can try adding port 443 to the list of ports that the controller will watch to redirect to the authentication page.
12-07-2009 04:47 PM
config network web-auth-port
12-09-2009 01:17 AM
Thanks for the feedback, however I've added the 443 port and the traffic
is still not redirected.
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80,443
Fast SSID Change ........................... Disabled
802.3 Bridging ............................. Disable
Any other suggestion?
Aziz
12-09-2009 05:01 PM
Looks like you were initially correct with your observation - it's a no-go due to CSCar04580.
The cisco.com version of the document is at http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a38c11.shtml (search for CSCar04580). The way forward would be to contact your Cisco account team and request the feature if it is needed.
